Keyboard?
I read one of the posts that indicated the extender can accommodate a USB keyboard. Does this require some setup? I tried plugging my keyboard in via the USB port, and nothing seemed to happen. That is, I tried to use it to type in some search terms to look for programs in the guide, but there wasn't a response. Entering search term with the remote is, well... tedious. I can, of course, just go in the other room to the computer... but I'm too lazy for that.
What firmware version are you using? What version of SageTV on the server?
If SageTV & the firmware are up to date, you should just be able to plug in the keyboard. Perhaps try unplugging the HD200, connect the keyboard, then restart the HD200. - Andy
They're both the latest. I've been preoccupied with a system freeze/lock problem, so haven't tried it more than once. I'll do as you suggest, now that it looks like I've got stability. (I don't know what I did to get stability, though. The problem just seems to have gone away for no reason.)
Client PC - What Keyboard Do You Use? | Brent | Hardware Support | 18 | 12-08-2008 07:42 PM |
Keyboard Commands for MC? | Stuntman | SageMC Custom Interface | 5 | 12-04-2008 01:27 PM |
What keyboard for sagemc? | AJ Bertelson | Hardware Support | 0 | 11-06-2008 09:50 PM |
Keyboard Shortcuts? | phenixdragon | SageTV Software | 5 | 02-02-2006 10:20 AM |
Keyboard shortcut | hoppala007 | SageTV Recorder Software | 1 | 12-27-2004 05:30 AM |
