some hiccups in the audio spdif
Ok, I'm don't think it's a v7 (because I had the same issue in v6).
I was having some issues, with some stuttering (video) but turned out to be a failing hard drive. Before I found out it was that, I updated the firmware to the beta v6 firmware (forgot what it was for). Then fixed the real problem, then noticed the small hiccup in the sound (like when you push mute then unmute but very very fast). If I rewind to listen to the spot again its fine. I say it happens about every 4 to 6 minutes. No video skips. I don't remember it before the v6 beta firmware. Anyone else has any ideas?
Server: HP AMD64 dual core running Win7 64bit (MCE disabled) with 4G memory Tuners: 2 PVR-500(disabled), 3 HDHR and 1 HDPVR Clients: 2 HD200 and 1 HD100 TV: 70" and 52" and 42" Media Storage: ReadyNas 8TB Recording media: 300GB + 200GB+ 250 GB Network: Gigabit backbone' Thanks to all the developers who work on SageMC, code, utilities and plug-ins to make SageTV better!!! ![]() |
I'm using the box connected to sagetv server. I'm using SPDIF to my receiver for audio and hdmi to video. I had another HD200 box and did the same thing.
I did notice for the setup for the box (in standalone mode), has hdmi/spdif for digital pcm and digital bitstream. When was this put in? I'm going to try to change from pcm to bitstream to see if that makes a difference.
Still have an issue with the other box. used same power cord. This could either be a network problem or power problem or another.
Anyone has some ideas?
It's likely a reported issue of audio drop-out. Check the DTS thread.
Bruno Twisted Melon Inc. While you're clicking, check out my Mini Theater custom build. |
Two Extenders ... One has the Hiccups (SPIDF Audio Skips ) | Qusix | SageTV Media Extender | 1 | 11-08-2008 10:47 AM |
Ac3 audio over spdif | bigbeav | SageTV Placeshifter | 7 | 07-04-2008 04:13 PM |
Audio Pops using SPDIF | wylee | SageTV Software | 0 | 10-31-2007 06:29 PM |
Audio from both SPDIF and analog | xcor635 | Hardware Support | 9 | 07-13-2005 12:16 PM |
No audio out using SPDIF | Jesse | SageTV Software | 3 | 03-14-2005 08:48 PM |
