SageTV United Kingdom SageTV and SageTV Recorder Users from the UK - This forum is for you to post about specific issues using SageTV software in the UK. |
EPG Broken after 2 weeks on vacation!
Hi Gents,
switched off my system whilst on vacation. On return, the EPG (using Donators version 4.3 of Stephanes tool) is only partially populated; many channels are showing no data but some channels are fully populated with the listings from Digiguide. Digiguide is a full subscription and is correct. XMLTVGUI or DG2XML both work perfectly with no log issues (other than categories warnings) yet, most of the major channels are showing NO DATA. I am running SAGETV 7.0.12 which is stable in every other sense. I have checked the channel mappings and all seems OK, all channels are working perfectly just do not have complete listings. How do I clear and reset the EPG to get things back to normal? ![]() Cheers
Server: Tranquil T7 Intel Atom D330, 2GB RAM, Windows Home Server, Sage TV 7.1.9 (Last version ever ![]() Clients: 3 HD300s, 2 HD200s, 1 PS3 |
Solved it; a bug in SageTV it seems.
in the EPG lines in the Sage.Properties file is a 'last update date' option. This (IF NOT CLEARED) means the the EPG does not update from the current date forward; clearing this line from the properties file and re-running the EPG update (Stephanes Importer) solved the problem. Seems a bit poor but there you are ![]()
Are you sure you waited for Sage to update its EPG with the new data? This can take up to 24hrs.
But if you think you have found a new bug it would be worthwhile reporting it http://www.sagetv.com/bugs.html
2 X HD300, 2 X HD100 & KVM unRAID Host with SageTV Docker using TBS 6285 Quad DVB-T2 & TBS 6984 Quad DVB-S2 Tuners |
Yes I waited 3 days before meddling.
Sage seems to think the next EPG update day was always yesterday; no idea why. Clearing the EPG update properties entries clearer the problem up by next morning.
Vacation Precautions - What Else? | dadof4 | Hardware Support | 9 | 03-02-2009 09:44 AM |
Why only 2 weeks | snoopy | SageTV EPG Service | 2 | 10-12-2006 08:38 PM |
Extend EPG Data beyond 2 weeks | Tenspeed | SageTV EPG Service | 1 | 09-06-2005 09:43 AM |
3.0 a few weeks away? (unofficial announcent discussion) | Crashless | General Discussion | 46 | 05-03-2005 05:14 PM |
This weeks specials | kny3twalker | General Discussion | 5 | 08-06-2004 07:39 AM |
