View Poll Results: Does your Dish Network service go out frequently in bad weather?
Yes 5 31.25%
No 11 68.75%
Voters: 16. You may not vote on this poll
Old 09-30-2010, 09:53 AM
APillowOfClouds APillowOfClouds is offline
Dish Network performance in bad weather
Does your Dish Network service go out frequently in bad weather? I'm in the final stages of considering a switch to them from Cablevision and I have a lot of people warning me about Dish not working in bad weather.
Old 09-30-2010, 10:05 AM
blade blade is offline
I had DirecTV about 10 years ago and if there was ice on the dish or a hard rain the picture would break up. I adjusted the dish many times trying to improve the performance, but I was never able to get a good picture during bad weather.
My uncle currently has Dish Network and he told me last week that he loses picture during bad weather and that my cousin has the same problem with her DirecTV.
I've had people tell me (on the internet) they never lose signal in bad weather and that mine must not have been setup properly, but I've yet to meet anyone in the real world who says they don't have problems from time to time.
I live in the south east part of the US and have wondered if what part of the country you're located in makes a difference.
I didn't vote because my first hand experience is from awhile back and everything else I've heard is second hand.
Old 09-30-2010, 10:40 AM
sleonard's Avatar
sleonard sleonard is offline
When I had Dish (late 90's) it would only go out in the most severe storms. Those storms were the ones that had me going around and unplugging my electronics so the signal quality was moot anyway.
S
Old 09-30-2010, 10:46 AM
panteragstk's Avatar
I had dish for 4 years and never had issues unless there was ice on the dish.
Old 09-30-2010, 10:52 AM
Skirge01's Avatar
Skirge01 Skirge01 is offline
I have DirecTV, but I doubt the technology is all that different, so the facts are probably quite similar. I would also be likely to say that I "never" lose the picture in bad weather, but what that really translates to (as a SageTV user) is that I very rarely lose the picture when a show is due to record. When it does, I just reschedule it. Now, if your area is prone to very heavy rain with thick cloud cover or serious snow storms which last for hours, a satellite provider may not be the best choice.
Software: SageTV 7
Old 09-30-2010, 12:25 PM
SWKerr SWKerr is offline
I have had DISH before and currently have DirecTV. Both will go out during a severe thunderstorm. Normal rain is just fine but anything that shows up red on the Doppler radar map will block the signal. Ice and Snow are rare here in North Carolina so not really sure about them.
My tuners are a HDHR with an antenna and two DirecTV H20 with HD-PVRs. It is really only a few times a year that I ever see the problem but I can force an OTA recording for most things if I think it may be a problem. Also:There is usually an online source if you actually miss part of a recording.
Also: Quality of the HD Cable choices and feeds I have seen in my area sucks.
Old 09-30-2010, 04:40 PM
RocKKer RocKKer is offline
I live in No CA USA and had to peak the aiming of my dish, previously I lost signal during some heavier weather after I peaked it I haven't lost signal in any weather (so far!). The multi-satellite dish requires an accurate aiming to get sufficient signal in heavy weather situations and the installers don't always take enough time to set them up accurately.
Several years ago I was losing signal only during and after a rain. The white plastic dome on the LNB had deteriorated to the point it let water into the LNB and messed with the signal. New LNB fixed the problem.
SageTV Server v9.2.2, Ubuntu Server 18.04.4 x64, Java 1.8.0_252, Xeon E5-2690, 32GB, 6X6TB WD Red - Software Raid 6, 2X HDHR3 (OTA), 3X HD-200
Old 09-30-2010, 04:51 PM
jerryt jerryt is offline
Satellite signals do not pass through water, only between the droplets. So the larger the dish the more rain fade resistant the reception becomes. Although in South Florida I will lose signal at times even with a 36" dish.
Do I need to connect Sage to a rain gauge next?
Old 09-30-2010, 07:31 PM
Fluffdaddy Fluffdaddy is offline
Severe thunderstorms only.
Were doomed. It will never work
Old 09-30-2010, 08:05 PM
CollinR CollinR is offline
Ditto
I use 3 of these.
http://www.solidsignal.com/pview.asp...u=615798309404
and
http://www.solidsignal.com/pview.asp...omponents&sku=
plus one of these
http://www.solidsignal.com/pview.asp...iswitches&sku=
Thats good enough for 4 tuners and I only lose 129w when it gets really bad out. I dunno that I have ever lost 110w or 119w.
Having 1 dish per orbital makes it MUCH easier to DIY peak/align them, also if an LNBF fails I can just swing one of the others over. I could support a max 12 tuners by adding more DP34 switches.
I ran 2 RG6QS from each LNBF to my network cabinet where I installed the DP34 on 1 from each leaving the other for future expansion.
In OK we have ice storms that can take out power for extended periods, Cox is good for about 6 hours before they fail. Dish is no problem running from my genset.
I'm enjoying it!
Old 09-30-2010, 10:42 PM
I've had Dish for a few years now, and have never had problems.. though, i live in southern california, so I have little rain, and a very high elevation on the dish. When I lived in Seattle, and had Voom, I needed a 36" dish to pick up the signal reliable in any sort of rain (keep in mind, Voom only had one satellite, and it was south of Florida... not an easy pick from the Pacific northwest...) Still, once I put up the big dish, it worked out great.
I'm not sure they make over sized elliptical dishes that are 'required' for current sat setups. You may have to go to 2 or 3 large round dishes to get all the birds you need if you want to replace the smallish elliptical.
Old 10-01-2010, 07:13 AM
PLUCKYHD PLUCKYHD is offline
Ah explains so much
Old 10-01-2010, 07:57 AM
tmiranda's Avatar
tmiranda tmiranda is offline
Originally Posted by PLUCKYHD View Post
Ah explains so much
Old 10-01-2010, 08:34 AM
sic0048 sic0048 is offline
I only loose signal during the most intense thunderstorms/rainstorms. So yes it does happen, but not very often.
The other thing that can cause a loss of signal is snow accumulating on the dish itself. But Dish no longer will mount directly to a house, so most installations will be on a pole located at ground level. This makes it easy to keep the snow off. If the dish was on the roof, it would probably be more of an issue.
SageTV v9 (64bit)
OpenDCT
Using CQC to control it all
Old 10-01-2010, 12:21 PM
fidget's Avatar
fidget fidget is offline
I see the same thing here. I am in eastern Iowa, so we do get severe thunderstorms. FWIW, I have more problems with the local Fox station that I do with the Dish receiver.
DVD Storage: 24 TB
Clients: 3
SageTV Extenders:5
Old 10-01-2010, 12:50 PM
Thanks for all the input. I think I'm going to give it a try and I'll be back here for advice on aiming/larger dish if I have issues.
Old 10-01-2010, 12:55 PM
Not sure how to answer the poll, it depends on what you consider "bad". I'd say like most here, "bad" weather isn't an issue (probably 5 years on Dish here), it's only "severe" weather that's an issue.
I always laugh a bit when I see one of cable's commercials talking about rain fade. Why? Well because while it's true there is rain fade with satellite, it's predicable (you know the bad weather is coming) and it's rarely more than a couple minutes. In contrast with cable, I've seen way more random flakyness.
Satellite, outside of severe weather is as near as makes no difference, perfect. I can't say the same thing for cable from my experience with my parents' service or that of my friends.
Oh, and if your area is like mine, satellite slaughters cable in terms of HD availability. I think there's only 2 channels I ever record anything on that aren't HD on Dish, it would probably be more like 50% if I had cable.
Old 10-01-2010, 01:56 PM
I think this has been covered well enough, but what the heck I'll throw my experience in as well:
In severe weather I will lose signal. However, I capture my locals via ClearQAM and OTA so even when my dish loses signal, I still get all of the network shows and I still get the local weather to know whether to take cover! Further, cable channels generally play shows over and over again, so whenever the weather causes me to miss a show, I just tell Sage it was a wrong recording and it records it at a later date.....
Severe weather and college football coincide is the only time I miss cable and then I just make a drive to my favorite watering hole instead....
Old 10-03-2010, 09:08 PM
In my previous post I used the term bad weather and I've seen a lot of people using the term severe weather. To be more clear when I said bad weather that included very heavy rain with no lightening or high winds.
As for people with spotty cable service, I think that really depends on your provider and maybe more importantly your local office.
Old 10-04-2010, 09:10 AM
It's pretty much got to be a thunderstorm in my experience. And beyond that it has to be largely south of you. Or to put it another way, basically what it takes to knock out the signal is a big, tall, high precipitation cell that lines up directly between you and the satellite. Basically means a rather strong thunderstorm that covers the area south of you.
The location is key, because IIRC I've been hit with a pretty strong thunderstorm in the past, but I was on the very south edge of it (not much of the storm south of me) and it didn't take out the signal.
My point though is weather is really the only thing to worry about with satellite. Any other problems is going to affect all of their subscribers and as such is fixed very, very quickly. Where as with cable, if you're unlucky enough to get spotty service, there's much less incentive because you may be only one of millions of their customers with that issue. Cable can go out for hours or days if something goes wrong.
Satellite, worst case you're out for a few minutes while the storm passes.
Using Weather Network as a feed for Canadian Weather Fastrack SageTV Customizations 2 03-22-2009 09:47 PM
Wireless MVP performance on G network dinki SageTV Media Extender 5 08-21-2008 02:51 PM
Problems with Dish Network, USB-UIRT, Dish 311 receivers e4gulf Hardware Support 8 05-31-2006 09:53 AM
Bad performance on my laptop rajohnston SageTV Software 2 08-18-2004 02:01 AM
SageTV Client poor network performance Beelzebub SageTV Software 1 08-14-2004 11:17 AM
