SageTV v7.0.18 - 2250 - QAM HALTS [RESOLVED]
Since installing the .18 build, my 2250 has had 'halt detected' about 5 times, whereas normally, and with all previous builds, this was never really an issue. I actually can't recall the last time one occurred, but it was many months ago.
With .17 and earlier builds, this was not occurring. I installed .18 Friday evening, and since that time, 5 of my records have had 'HALT DETECTED' on QAM channels, to various degrees of failure. Most had moments of time missing, but the Simpsons at 7 on Sunday was unplayable. No other changes were made to the system, except this .18 build, when the issue started. In an attempt to fix the issue, I installed the latest 2250 drivers this morning, but this has made no difference, since of my 5 Sunday items scheduled, 1 has failed with Halt Detected. On the same network, three other recordings before and after recorded fine.
DON3k |
happening here on all hdhr recordings, but the recordings are all fine (just the warning)
i saw another thread that says they know of the problem with the hdhr and will have a fix/load shortly
Q: dad, when will you stop changing all the electronics? A: never, so you might as well get used to it. |
Just a FYI I've seen some messages about the .19.1 (.34) DShowCapture.dll file possibly fixing QAM issues, so I've installed that, to see what happens.
My QAM channels on the 2250 are still tuning, so nothing appears any more broken than before, so hopefully I'll see the Halt Detected issues gone.
DON3k |
did the .19.1 (.34) DShowCapture.dll file help?
Gigabyte GA-MA770-DS3/4gb DDR2/AMD Phenom 955 3.2ghz Quad Core Windows 7 64bit Home Premium Hauppauge 1600/1850/2250/colossus/2650(CableCard 2 tuner) 8tb RAID5 storage/media/other &3tb RAID5 backup storage on a HighPoint RocketRaid 2680 1tb 3 disk Recording Pool all in a beautiful Antec 1200 SageMyMovies/Comskip/PlayON/SageDCT/SRE HD100/HD300 extenders |
I don't know if I can say, for sure, yet.
I applied the updated DLL after all my Sunday Night recordings were complete. It recorded a couple of things today okay so far. I'll know in the next day or so, since it was doing it at least 1-2 times a day after the .18 beta install. I just don't have a lot on my lineup for today.
DON3k |
Try a new update
I just updated the patch
DShowCapture.dll (file version 3.0.36). Have a try. Edit: http://download.sage.tv/users/qian/7...howCapture.dll Qian
Qian Last edited by donkey; 10-04-2010 at 02:24 PM. Reason: Fixed link |
Your link appears to be bad.
Can you paste it again? I found the link in your other post: http://download.sage.tv/users/qian/7...howCapture.dll
DON3k |
In my case, I thought the channel mapping had gone out on my 2250. I had removed the sources and started the process of remapping the 12 QAM channels I have.
With either the newest DLL posted today or the .18 or even going back to .17, I get 100% signal strength but no preview video. I haven't dared touch the HDHR sources since they still work. One thing I noticed is that HDHR tuners are showing QAM while when I setup the 2250 tuners, they show as QAM NET. I'm going to check the sage.properties to see if that has any impact. Edit: Okay, I've managed to get the 2250 working with .17 now. Though I can't preview any other channel besides the first one I try while in channel setup. I have to exit that screen and go back to test the others...which do tune. Atleast things are somewhat working now. ![]()
Windows Vista Ultimate 64-bit Dell Studio 7100 Athlon Phenom II X6 1035T 2.6GHz ATI Radeon HD 5770 1024MB GDDR5 WD 1TB Recording Drive/WD 1.5TB 1X HVR 2250 (Dual QAM) 1X HDPVR 1X HDHR Last edited by Mayhem70; 10-04-2010 at 06:12 PM. Reason: more info |
My 2250 has been broken since I upgraded to .18 release candidate. The analog side works fine, but the QAM tuner gives me an error that says "a Sage component is broken. Please reinstall Sage" or something close to that. I've uninstalled and reinstalled several times to no avail.
Will try to roll back to 7.0.16 tonight to see if that helps.
Rick Sage Beta 7;HD-300;Windows 7 64-bit;HP EX495 server with 7tb;Ceton 4-tuner cable card. |
IM2BZ2P: did you try the DLL update from a few posts above yours & also mentioned in the v7.0.18 release thread?
Andy, when I get home from work tonight I will try it and report back before I roll back to an earlier beta. Thanks.
Well, two full days of use, and no HALT errors.
So it appears the DLL has fixed the issues I was having.
DON3k |
Andy, I just updated the DLL and the pvr-2250 appears to be working. The error message no longer appears and the channel scan is finding new channels. Thanks.
Not only has this dll fixed my halt issues, but my 1600 that was finding 0 qam channels found 33 on a new scan, with signal strengths around 85%.
THANK YOU!
I installed Sage .19 and I noticed that it came with the old .33 DLL...
I reinstalled the .36 DLL - I didn't want a rash of the HALTs again this weekend. Any reason the fixed DLL wasn't part of the Sage .19 release? Was the .33 DLL fixed in some way?
DON3k |
There is now a Sage .20 release available.
My question still stands, as the .20 release also installs the .33 DLL
DON3k |
Does the .20 release fix this issue? I have been having mucho "Halt Detected" errors since going to .18 with my previously bulletproof (mostly) HDHR...
{Server} | i5-3330S | Z77X-UD5H | 8gb DDR3 | Windows 10 Pro | {Tuners} | (1) HDHomerun (OTA) | (1) HDHomerun Prime + OpenDCT on Comcast | {Client} | (2) HD300 Extenders | (1) PC Client | Mi Box Android Client | FireTV Stick | |
Well, the .36 DLL linked in this thread fixes the issue, for sure.
DON3k |
We don't always increment the version numbers on the DLLs and EXE files, so don't go off that to determine if the file is different or not. .20 should include those fixes, that was the whole point of it over .19 (since some of those fixes accidentally got left out of .19 due to a hard disk failure)
HVR-2250 & SageTV 7 clear QAM issue | gcamp0730 | SageTV Beta Test Software | 49 | 10-31-2010 02:47 AM |
7.0.13 and Hauppauge 2250 QAM | kkeller20 | SageTV Beta Test Software | 5 | 08-06-2010 09:40 AM |
Hauppage 2250 and Clear QAM | will | Hardware Support | 17 | 12-19-2009 05:56 PM |
2250 No QAM | vtac | Hardware Support | 4 | 03-15-2009 08:57 AM |
HD homerun vs HVR-2250 for un-QAM | AJ Bertelson | Hardware Support | 0 | 10-27-2008 02:44 PM |
