Microsoft Malware Protection Center
I have seen these java exploits first-hand, and let me tell you they are no joke. They can get around UAC, and they can get around security products. Once installed, they prevent execution of task manager, registry editor, the command prompt.. pretty much anything you need to attempt to clean them. They install malware all over the place, setup listeners and browser proxies. I even saw one that corrupted Symantec Endpoint. Running as an un-privileged user is helpful but will not stop the install if you get exploited. You'll have to logon as an Admin and clean with up-to-the-minute security product. Blocking java applets in browser options is the only option I see, unless SageTV can give us guidance on keeping Java updated?
SageTV server & client: Win 10 Pro x64, Intel DH67CF, Core i5 2405s, 8 GB ram, Intel HD 3000, 40GB SSD system, 4TB storage, 2x HD PVR component + optical audio, USB-UIRT 2 zones + remote hack, Logitech Harmony One, HDMI output to Sony receiver with native Intel bitstreaming |
Why is this SageTV's worry? If you don't want your machine to get infected, don't use it for anything but SageTV or switch to Linux
![]() B
Running SageTV on unRAID via Docker Tuning handled by HDHR3-6CC-3X2 using OpenDCT |
As far as I can tell these exploits are when using Java embedded in a browser; i.e., using applets--especially those of unknown origin. SageTV isn't based on applets, though it does use Java under the hood.
Rich |
Same stuff would happen if you browsed the web on your cable box, just keep SageTV as a single use appliance and you have much less to worry about.
That's what I do.
I run Java v1.6.x on my desktop station and it handles the Sage Client just fine. It remains updated.
I probably have the Sage-installed 1.4.x on my WHS box, but being literally just a server, there's zero web browsing on that machine. The homepage for the machine is Windows Update, so the likelihood of a problem there is minimal. (All home machines are behind a physical firewall) Although it pays to pay attention to these threats, just make sure you have mitigating controls or behaviors in play to prevent them from being a big concern. -Greg |
I do not browse from my SageTV server.
However, my SageTV Client is on my main workstation, where I spend the vast majority of time in my browser. Unfortunately, my all online school schedule requires both java for programming as well as java (and flash) through the browser. Disabling either (or running something like noscript) is simply not an option.
"Backdrops" "SageTV" "Covers" folders - what's creating them | mp328 | Sage My Movies | 4 | 09-20-2010 05:31 PM |
JAVA "MainMsg"" error help | Graygeek | SageTV Software | 0 | 09-01-2009 04:04 PM |
Can anyone customize for me a Sagetv import for "movie now" "news now" .. menus | thenewguy1979 | SageMC Custom Interface | 9 | 09-18-2008 02:41 PM |
"Set defaults" for Series forgets "Keep"/"Auto-delete" setting | maxpower | SageMC Custom Interface | 9 | 05-14-2008 09:44 PM |
Java Error? "unexpected error" "exception_access_violation" | gotuitdan | SageTV Software | 1 | 11-21-2006 10:49 PM |
