Old 12-03-2010, 09:40 AM
mkanet's Avatar
mkanet mkanet is offline
Question Automatic login doesnt work when launching placeshifter from command line
I did several searches on this sub-forum, but I can't find a post which tells you how to connect to the server and login automatically. It's either one or the other; even if I have automatic logins enabled. I did see one post which requires installing another piece of software to automate key presses (which I REALLY want to avoid).
The only time I am able to use the automatic login feature is to launch the Placeshifter executable directly and manually select the server every time.
Is this a bug with automatic login or maybe I need to modify my command line to include username/password? I'm sure there has to be support for this.. its just not too obvious. I even looked through the latest sageTV manual.
start /separate /min javaw -cp MiniClient.jar;jogl.jar;gluegen-rt.jar sage.miniclient.MiniClient serveripaddress
Thanks in advance!
***RIP SageTV***
Old 12-06-2010, 11:05 AM
mkanet's Avatar
Anyone??
***RIP SageTV***
Old 01-27-2012, 05:59 PM
dan596 dan596 is offline
open placeshifter automatically
bump Anyone?
Old 01-27-2012, 06:12 PM
mkanet's Avatar
This was fixed in one of the latest builds of SageTV 7. I dont have that problem anymore with the latest SageTV server+sageTV placeshifter.
***RIP SageTV***
Old 02-20-2012, 07:34 AM
mzup mzup is offline
How do I get this to work? What am I missing? I type in that line and I get can't find start.
Running Windows XP. Running latest version of SageTV and Placeshifter.
Old 02-20-2012, 11:33 AM
mkanet's Avatar
What does "I get can't find start" mean? It would be very helpful if you can you type exactly what command-line type typed and what happens when you press enter? Do you get an error message at the command-line; if so, what's the exact error message from beginning to end.
***RIP SageTV***
Old 02-21-2012, 04:05 AM
Well in your first post you wrote this:
That is what I mean start. I typed that line in and ran it and got the error 'Windows could not find 'start'. Make sure you typed it correctly.
Old 02-21-2012, 07:46 AM
mkanet's Avatar
You have to run it from the Windows command prompt. You cant paste that in a "run..." dialog box. The idea is to make a batch file (or shortut) that you can double-click). You also need to replace "serveripaddress" with the IP of sageTV server.
***RIP SageTV***
Old 02-21-2012, 03:10 PM
Got it. So I put it in a dos window and ran. No errors, but nothing happens.
Launching Studio From Placeshifter voorhees SageTV Studio 7 08-11-2013 02:04 PM
Placeshifter automatic login 44kebeck SageTV Placeshifter 2 04-26-2010 09:35 PM
Adding custom command for launching external program dinki SageMC Custom Interface 14 01-22-2010 08:16 AM
Automatic Forum Login tmiranda General Discussion 12 01-19-2010 04:03 PM
How do I send command line or Event messages to Placeshifter? mkanet SageTV Placeshifter 3 10-08-2009 01:44 PM
