Batch Metadata Tools This forums is for discussing the user-created Batch Metadata Tools for SageTV. |
DVD Covers aren't being saved
I've been using BMT for a while now and I have never had a problem. I have the latest release installed and now DVD covers aren't getting saved automatically. The metadata is getting downloaded properly, but images are never there. I have to use the IMDB plugin to search and save the cover image. BMT images are higher quality than IMDB, so I would prefer to use that. I tried to create a support ticket via the BMT web ui, but I get an error:
"500 The call failed on the server; see server log for details". Which file do I look for on the server for details? Would just uninstalling and reinstalling fix it? Thanks
Server - Windows Home Server: Sage 7.1.9 HVR-2250 and HD Homerun Dual Tuner, Intel Core2Duo 2.4GHz, RAM 4 GB, HD OS/Movies/Music/Pictures:500GB (SATAII) TV:1TB (SATAII), Clients - 2 x HD-300, 3 x MediaMVP |
Check to make sure the tmdb server isn't having issues. The Movie Database (tmdb) is the default resource for the DVD covers.
From the status page, Fanart Enabled = True, Automatic Metadata/Fanart Lookups Enabled = True. Fanart Folder = F:\SageTV\Fan Art. Inside this folder is Movies and TV. Not sure what you mean by folder set correctly. It seems to be correct to me as I can see fanart images in Sage.
Is there anything else I can try?
When you say the UI do you mean the BMT Web UI?
As for the UI, yes, the BMT web ui. Thanks
Does that mean if I disable fanart that BMT will create a cover with the media?
Yeah, if you disable fanart, then bmt may start writing a the poster file as the video thumbnail (or cover) in the same directory as the video file... but it will NOT download anything to the central fanart area, and so you will not get backgrounds.
But, you can generate the .jpg if you want, manually. From the Tools menu select "Export SageTV Media Thumbnail"... or browse a view/folder and use the "Batch Operation" menu and select the "Export SageTV media Thumbnails". They both do the same thing, except that from the Tools menu, it will act on ALL files... whereas the Batch Operations drop down only acts on the current view/folder (and sub folders).
OK, that is good to know. I know I have had problems with Fan Art in the past showing the wrong images. For example, once a new show that didn't have fan art got downloaded, all new shows showed that Fan Art image instead. I didn't really have the time to troubleshoot, so I just turned off Fan Art, but I might try it again and hopefully if it happens again, you can help me make it work.
Thanks for the quick responses!
Favorites not being saved | samvonac | SageTV Software | 3 | 01-12-2009 08:03 AM |
Sage saved my day | mjrogers99 | General Discussion | 1 | 12-28-2008 09:50 PM |
Saved Searches | shawnvw | SageTV Software | 4 | 06-10-2008 01:25 AM |
Video directories not being saved | mc2wheels | SageTV Software | 6 | 12-15-2004 10:53 AM |
saved IR Codes | m0ng00se30 | SageTV Beta Test Software | 0 | 03-06-2004 08:13 AM |
