High end universal remotes
Do you have one? If so which is it and would you recommend it?
Hi,
I like the logitech harmony remotes. The concept of "activities" makes using your media devices a real joy. The model you choose depends on the money you want to spend. I think all but the cheapest model support "activities". Best regards, Eyk
Clients: HD200, MediaMVP Capture Cards: Technotrend Budget S-1500 (DVB-S) STVi for XMLTV icons |
Have you used the 1100?
I've have a 1000 (basically the same as the 1100) I've actually gone to the Harmony 900 with the latest physical layout. That actually works the best. The touchscreen is cool at first but everyone in the house likes the physical buttons better. The 900 has IR and RF control built in (which adds to the cost)which I set up for the living room. Works the best out of my 1000, 880, 700 and 520. I end up getting these as either refurbs or when they are on sale. The 700 is my new low end standard. The Harmony 300 does not support activities. I've also had some issues on the 1000 with the physical buttons sticking sometime. Very aggravating. I caught the 900 on sale for under $200 not too long ago. My 1000 refurb ran $125. The 700 was recently purchased refurbed for $64.
Big Gerr _______ Server - WHS 2011: Sage 7.1.9 - 1 x HD Prime and 2 x HDHomeRun - Intel Atom D525 1.6 GHz, Acer Easystore, RAM 4 GB, 4 x 2TB hotswap drives, 1 x 2TB USB ext Clients: 2 x PC Clients, 1 x HD300, 2 x HD-200, 1 x HD-100 DEV Client: Win 7 Ultimate 64 bit - AMD 64 x2 6000+, Gigabyte GA-MA790GP-DS4H MB, RAM 4GB, HD OS:500GB, DATA:1 x 500GB, Pace RGN STB. Last edited by gplasky; 06-09-2011 at 12:21 PM. |
I have been quite pleased with the Harmony 650 because I like the 'Activities' concept, programming is a snap because of the huge code base of audio/video equipment(which includes SageTV), the layout of the remote ect....
The 650 is limited to only (5) audio/video components but the most I have is (4). I have three of them and they were a snap to setup so that no matter where my wife is viewing all she has to do is pick up the remote and do exactly what she did at the last viewing area. I paid as little as $60 and as much as $70 for mine.
bits ![]() PC: W7 32bit, Intel Q9550 2.83 Quad, 4GB DRAM Cap Devices: Colosuss+UIRT+Cable STB; HDHR QAM+OTA, USB MediaSonic (6TB) Network Players: HD200, (2) HD300s Viewing: Samsung 55" 8000, Sony 50" and HP 37" The more complicated it is the more likely it will break! |
I have 3 Harmony 880's. I also love the Activity concept and the 880 has a particularly good button layout and shape that fits in my hand well. I want one more but unfortunately the 880 is discontinued.
S |
I'm currently using a Harmony One and before that a 525, I'd quite happily recommend both of them, although I prefer the feel of the buttons on the One.
As for cost, I owned the 525 for a couple of years before I started to have some issues with it, when it came to replacing it, cost wasn't even a factor, I just knew I had to have another one...
Server: Win7 64bit; i5 2500; 32GB ram; Blackgold BGT3595; 18TB + 120GB SSD; Edgestore DAS401T; DVBLink; Oscam; Omnikey 3121 Lounge Client: HD300; Yamaha RX-V765 connected to 55" Furrion 1080p LCD; Logitech Harmony One remote Kitchen: HD300 32" LCD, Bed 1: HD300 - 40" LCD, Bed 2: HD300 - 24" LCD, Bed 3: HD300 - 22" LCD |
I have 2x Harmony 510 and 2x 520 remotes. The are perfect. I think I bought all of them for $50 or less refurbished.
Before that I had 2x Harmony 688. They all worked great. (Still have them just retired in favor of the others) I think it is more about the configuration software than anything. Combine them with a MCE IR receiver or USB-UIRT and LM Remote or Event ghost and you can control anything.
Retired SageTV in favor of Plex\Emby and YouTubeTV. |
Harmony One
SageTV server & client: Win 10 Pro x64, Intel DH67CF, Core i5 2405s, 8 GB ram, Intel HD 3000, 40GB SSD system, 4TB storage, 2x HD PVR component + optical audio, USB-UIRT 2 zones + remote hack, Logitech Harmony One, HDMI output to Sony receiver with native Intel bitstreaming |
Well I personally wouldn't call Harmony's "high end" I've always thought they felt cheap. URC is more high end (really high end is more like RTI). I'd highly recommend URC though, the remotes are very solid, far more solid than Harmony remotes, and IMO they're much easier to program. Though you do have to be able to plan out your own macros and variables.
I'm with stanger on this one. I've been using my URC MX-700 for 10 years now. Built like a tank and just always works. And it just FEELS serious
![]() While I like the concept of activities on the Harmony, they are very inflexible. Or at least, they were the last time I tried them. With the URC, I can build macros the way I want. So I end up with the same idea as activities, but exactly the way I want. |
I have the Harmony 1100 and my wife and I love it! I would highly recommend it to anyone that is looking for a great all in one remote.
That being said i have owned and used many Logitech remotes, and have loved every single one i have used. |
I had two Harmony 520s where buttons began failing after only one year. One was still in warranty and fortunately Logitech replaced it with almost no questions asked... the replacement also failed after one year. I've replaced my broken 520s with Harmony 510s (which is basically the same remote) and luckily those buttons have all held up for the last 18+ months (knock on wood). The Harmony One seems a little more solid, but I'm not interested in spending $100+ on a remote. All-in-all I love the look and feel of the remote and they have great customer service. But I agree they seem cheaply made, so don't be surprised if/when yours fail. |
I have had Harmonys and will never buy one again. They are too cheaply made, imho.
Of course, that is because, in my house, the remote gets drop/bumped off the couch, onto the tile (about 3 feet) at least once a day. For me, cheapest that does the job is best. The hard plastic on the harmonies just cracked to easily, i need the rubberized ones.
Gigabyte GA-MA770-DS3/4gb DDR2/AMD Phenom 955 3.2ghz Quad Core Windows 7 64bit Home Premium Hauppauge 1600/1850/2250/colossus/2650(CableCard 2 tuner) 8tb RAID5 storage/media/other &3tb RAID5 backup storage on a HighPoint RocketRaid 2680 1tb 3 disk Recording Pool all in a beautiful Antec 1200 SageMyMovies/Comskip/PlayON/SageDCT/SRE HD100/HD300 extenders |
I have owned several URCs, including a 700 and an 850. Extremely well designed (except for the center button on the 700 which was fixed on the 850). They cater to custom installers and are stingy with their software updates, included IR codes. But the software they come with accepts so many different formats that it is still worth it in my book.
Wayne
i5-6400, MSI B150M Micro ATX MB, 16GB DDR3 1600, 2 - WD Green 2TB SATA Drives, Lite-On SATA 4X Blu-ray Reader, Corsair 400W 80+ Power Supply, Silverstone Sugo SG02-BF MicroATX Case, Windows 10 (64), HDHR Dual X2, Quatro and Prime, 5 x HD300 + 2 x HD100 |
Harmony 880s, 890, 659.
An iPod Touch also works quite well as a remote using the mobile UI, or TiSageTV. As does an iPhone or iPad. And they use your wifi network so not LoS issues.
Wayne
URC
Universal Remotes MRF-350 and HD-300 | Peter_h | Hardware Support | 1 | 09-16-2010 03:49 AM |
Best universal remote? | ericscottf | Hardware Support | 49 | 07-06-2010 09:46 AM |
Universal remotes | SageGk | Hardware Support | 53 | 04-13-2009 03:41 PM |
HD 200 and universal remote | swats | SageTV Media Extender | 3 | 03-07-2009 05:48 PM |
Universal Remote with SR | dkardatzke | SageTV Recorder Software | 1 | 03-21-2003 03:48 PM |
