Old 09-22-2011, 07:27 PM
Phoenix Source (and how to rebuild Phoenix from sources)
Here are the steps for checking out Phoenix and rebuilding the phoenix.jar
Step 1 - Install Eclipse
Goto http://www.eclipse.org/downloads/ and select the first download link. It's the complete eclipse package.
Next you'll need to install the Subversion plugin for eclipse to checkout the source code
In Eclipse, go to Help -> Eclipse Marketplace -> Popular -> Subeclipse (or just search for subeclipse) and install it.
Step 2 - Check out the Phoenix Project
In Eclipse go to File -> New -> Other -> SVN -> Checkout Projects from SVN
Select Create New Repository Location
Enter https://sagephoenix.googlecode.com/svn/trunk/
Select 'Phoenix' and click 'Finish'
Step 3 - Configure the Project
When you checkout the project, or take update, and there are errors, then you'll need to run the ant configure task. You can run the configure task as many times as you like.
In Eclipse Right click on the build.xml file and select Run As -> Ant Build... (notice the dot dot dot), and then check the 'configure' target and make sure it is the ONLY target that is checked
This will download all dependencies except for Sage.jar. For Sage.jar it will prompt you for the location.
When it is complete, it will write the Eclipse .classpath file that is required to build your project. Once configure is complete Right Click on the Phoenix project and select "Refresh". Phoenix should now rebuild without errors.
Step 4 - Rebuild the JAR
Right click on the build.xml and select Run As -> Ant Build..., and then select the 'jar' target. (Make sure it is the only target selected)
The phoenix.jar will be built and placed in the target folder. If you don't see a target folder, then refresh your project.
Old 09-22-2011, 07:29 PM
Other Source Related Tasks
Regenerating the Pheonix API
TODO
Project structure
TODO
Running JUnit Tests
TODO
Using FindBugs
TODO
Old 09-22-2011, 10:26 PM
JonTom JonTom is offline
Thank you! I've been thinking about asking for this for the last few weeks.
Alpine Website Design
Phoenix UMB’s wrems Phoenix 2 06-24-2011 01:23 PM
Phoenix API stuckless SageTV Customizations 264 03-17-2011 11:36 AM
