Old 07-10-2012, 01:40 PM
atchoo atchoo is offline
Replacement Power Chord
Would someone know the power cord specifications for the HD-300 ? I lost my power cord when moving and need to replace it but would need the specs. I guess I can get a replacement at La Source with multiple voltage/adapters and it will fit but not sure what I should set it at.
Or if someone has a power cord for a defective unit that he would want to sell me, I can pay shipping + something for the cord.
Thanks.
Martin
Old 07-11-2012, 06:44 AM
pukka pukka is offline
i think its 12v 2amp, but i can check later if you like.
Paul
Old 07-11-2012, 07:24 AM
Re:
If you can confirm it would be appreciated.
Old 07-11-2012, 10:00 AM
dgeezer dgeezer is offline
I just looked at mine. It is 12V 2.0 Amp.
Old 07-11-2012, 07:48 PM
In the US (don't know about Canada), the HD300 came with a Honor ADS-24S-12 power adapter. Should be able to readily find them via Google...
Old 07-31-2012, 07:48 PM
Re:
Thank you very much, I ordered the ADS-24S-12 AC online for 19.95$ and it looks exactly like the one I had. Thanks a lot !
Replacement Power Adapters for HD-PVR - Toronto area kpbrwn SageTV Canada 0 12-28-2011 03:00 PM
HD-PVR replacement power supply dead_ferrets Hardware Support 5 05-26-2011 07:59 AM
Replacement power supply/adapter for SageTV Media Extender moakes Hardware Support 2 06-14-2009 09:11 PM
replacement osd bradlewa SageTV Customizations 3 09-19-2007 02:57 AM
Replacement for PVR-350 TV-Out SkierHiker Hardware Support 2 01-03-2006 04:58 AM
