Rebuilding Sage Server
After noticing a couple issues with sage on my WHS v1 (nothing major, just some small things) I am going to split the WHS and Sage but how well will safe run on a Quad Core 32 bit machine or will 4 GB of ram be enough for a x64 install?
My server will be Win 7 pro and it will have Playon, Sage, and com skip (commercial detector) also might try to get phoenix android app to work completely. So with 4gb of ram do I do 32bit or 64bit install?
Server: Win 10 Pro 500Gb OS, 1x 1.5TB & 2x 2TB HDs for recordings Tuners: 3 HDHRs OTA Client 1: HD100 on 65" Samsung 4K LCD\LED Client 2: HD100 on 50" Panasonic Plasma (16x9) Client 3: HD100 on 32" Toshiba Tube (4x3) |
64 bit uses about .5GB more RAM, but if you have ANY real IO on the MB (even a simple video card) you'll loose the .5GB (from 4GB) in IO space anyway, so that's a push.
I'm use 8GB on all my new machines, but mainly because that's the cheapest upgrade you can make. (add about $25, depending on RAM type) I'm only using about 2.5GB of RAM normally. Wow, I'm ALWAYS agreeing with Fuzzy. ![]()
Server #1= AMD A10-5800, 8G RAM, F2A85-M PRO, 12TB, HDHomerun Prime, HDHR, Colossus (Playback - HD-200) Server #2= AMD X2 3800+, 2G RAM, M2NPV-VM, 2TB, 3x HDHR OTA (Playback - HD-200) |
Thanks Guys..
64 bit it is.. The ram I need is PC2-8500 So I will satrt with 4GB and upgrade when I can. I need another 2 TB drive first though
The only reason to consider 32-bit is if you want to use Firewire to record or change channels on a set top box (there are no 64-bit drivers for this).
If you are sure you don't need to support Firewire, I'd go with 64-bit Windows.
Firewire is not needed.. Is a 7200 recommended for the OS Drive or will 5400 work fine?
just trying to use equipment I have.. I might have a PATA drive for the OS then use all the SATA for the Media
I'd recommend either an SSD for the OS drive, or any old hard drive with a large RAM disk cache.
I was using a laptop drive for my system drive until recently, so 5400 will be OK.
I was going to use the same thing, but I found I have a 7200 160gig drive to use
One other reason is if you have an older Hauppauge tuner card that doesn't have 64 bit drivers, I believe the PVR150 is one such card.
I have 2 or 3 PVR150s but no longer use them.. they are out of the machines as well
Good point about older capture cards... The PVR150 actually does have 64 bit drivers, but they are crippled (they puke if you install 4GB or more of ram), and the older PVR250 and 350 won't run under x64 at all.
Rock on...
Win 7 x64 Sage Server all set and the nice thing is it will double as a client when needed in the location I have it.. Phoenix App for Android works as well as Playon.. I off loaded my WHS V1 stuff to WHS 2011 on a dual core machine. So far so good
Rebuilding new system - few questions | Deano | SageTV Software | 9 | 12-31-2012 11:17 AM |
Rebuilding server: SSD or normal HD drive? | IVB | Hardware Support | 32 | 04-27-2012 05:00 PM |
Having problem getting OTA chanels after rebuilding server | rdefino | SageTV Beta Test Software | 7 | 03-21-2011 02:53 PM |
New to Sage (and rebuilding PVR) | JDJinTX | General Discussion | 8 | 03-12-2008 12:50 AM |
Rebuilding DB after crash | jlindborg | SageTV Software | 0 | 07-31-2005 01:36 PM |
