Old 08-04-2016, 05:22 AM
Smart TV & Mini-Client
I am in the market for a new TV and I was wondering if anyone had installed the mini-client into a Smart TV.
John
Servers: ChannelsDVR, Plex, AnyStream, PlayOn,
Tuner: HDHomeRun Connect Duo
Sources: OTA, Sling Blue, Prime, Disney+,
Old 08-05-2016, 08:29 AM
plawlor plawlor is offline
I have. I have a Sony Bravia. The client installs fine and runs pretty well performance-wise. It crashes and then exits fairly regularly, however. I haven't taken the time to try and figure out what's going on yet.
Peter
[SIZE="1"]Peter L.
Sage Server - Dual Intel i7, 16 GB RAM, 4 TB RAID 0 Disk, 5 x HD-PVR (BellTV HD), 5 x USB-UIRT, Windows 7 64-Bit on VMWare ESXI 5.1, SageTV 9.x Open Source
Clients #1 to #3 - HD300
Client #4 - Shield Android TV running Mini Client
Client #5 - Sony Bravia Android TV running Mini Client
Old 08-08-2016, 07:53 AM
I am deciding between a Sony and Samsung. Having the client install directly in the TV would be a deciding factor.
John
Old 08-09-2016, 09:12 AM
jm9843 jm9843 is offline
John
Well that makes it easy since only the Sony models run Android TV and are compatible with the miniclient.
Do be aware that the 2015 Sony's allegedly have problems with interlaced content. Silicondust have been in contact with them and have mentioned on their forum that the 2016 models 'should be fine' while an update is expected to resolve the issue on the 2015 line sometime 'this year'.
Old 08-13-2016, 07:13 AM
scoful's Avatar
scoful scoful is offline
Vizio/Yahoo Connected TV
Anybody have and idea if there's away to get the Mini-Client going on a Vizio SmartTV that uses Yahoo Connect TV?
SageTV 9 / 3 SageTV Clients / Ceton InfiniTV 6 / ComSkip
Old 08-29-2016, 10:04 AM
I decided on the Sony TV, but have not ried to load the mini cliet.
I did not realize that you need to login to your TV with your Google account.
They really are keeping track of everything you do.
Old 09-02-2016, 09:07 AM
panteragstk's Avatar
It's an Android device just like your phone or tablet. You want apps without side loading the you have to sign in. Apple and MS are the same way. No way around it now.
I created gmail accounts just for some of my devices. They have no information in them other than the email address so I don't have to worry about losing any personal info.
Old 09-02-2016, 09:36 AM
That's a good idea.
Old 09-06-2016, 05:13 AM
tmiranda's Avatar
tmiranda tmiranda is offline
I'm going to need a new TV soon. Any other TVs capable of running the mini client besides the Sony and Samsung? Do the TV manufacturers specify what OS runs their smart TVs? (I typically get Vizios because they are cheap and suit my needs.)
Old 09-06-2016, 05:33 AM
Here's my feeling on Smart TVs... Typically they are underpowered for most cases, but they still seem to do an OK job on Netflix, YouTube, etc. The problem I see is that you pay a fair price for the TV, but, better cheaper Android boxes are around $100-$200... in 2-3 years the TV is still great, but the "smart" features will likely become less smart and smaller cheaper streaming boxes will be better. I'd personally never pay "extra" to get a smart TV (I have one) but instead I'd rather put the money into a small client and update that every couple years.
Old 09-06-2016, 02:34 PM
I agree. To add to this there are instances where the smart TV's don't get their apps updated either. Plus the slowness isn't all that noticeable until you use a nice streaming box that zips through everything.
In the time it takes for me to launch netflix, select my profile, and start playing a show my shield is already 2 min into the same show.
My brother has a Sony Android TV and loves it. The only exception is that he gets a lot of force closes on apps that work perfectly for me.
Old 09-09-2016, 08:00 AM
That is my experience as well. MLB Extra Innings loses it's Internet connection a lot on my Sony Android TV. Runs perfectly for an entire game on my Rokus. The SageTV Mini Client runs well, but a lot of force closes. Could be a related issue. I haven't taken the time to really troubleshoot this yet, but it appears as though the Sony Android TV keeps losing and/or resetting its network connection all the time, causing trouble in most apps except Netflix and Plex, which both seem to handle buffering and replay way better than other apps. This may be what is causing the Mini Client crashes. Just a guess at this point...
[SIZE="1"]Peter L.
client for smart tv or blu-ray player korben_dallas SageTV Github Development 6 05-14-2015 07:18 AM
Placeshifter or Client Ap for Smart TV videolog SageTV Placeshifter 4 05-10-2011 06:20 PM
SageTV 7 WHS, client on Mac Mini? radiopaque SageTV Mac Edition 6 08-17-2010 04:21 AM
G4 Mac Mini as SageTV client? jbarr Hardware Support 2 06-28-2007 02:54 PM
Mac Mini as Sage HD client mikesm Hardware Support 3 01-05-2007 09:21 PM
