Help - HD300 UI Freezes
Hi All,
I have been working on switching my SageTV system over to Windows 10 and SageTV v9. It's been a big project, but have completed most changes and just about finished. However, I am receiving period (cannot recreate consistently) freezes while navigating through the UI through the HD300. Typically it is when starting to play a show, but sometimes it can occur just when scrolling through recordings. I usually get a Hang Detected in the log. Also, it usually will then clear up and I can continue, but occasionally, it hangs and I have to reboot the server (cannot kill Sage through task manager). ANY help would be greatly appreciated, I have been fighting this for a while now. Happy Holidays. Thanks!! Here are some more details:
Fri 12/23 20:24:06.502 [FinalRender-0023a5000227@12b05a0] MiniClient did not succeed with menu hint change to:menuName:MediaPlayer OSD, popupName:null, hasTextInput:false, errcode=1 Fri 12/23 20:24:06.625 [VideoFrame-0023a5000227@14dc4f6] getEstimatedBW=0 estimatedBWBytes=0 estimatedBWTime=0 Fri 12/23 20:24:06.625 [VideoFrame-0023a5000227@14dc4f6] MiniPlayer was not able to get a bandwidth estimate from the UI system, sending data to get its own estimate... Fri 12/23 20:24:06.631 [VideoFrame-0023a5000227@14dc4f6] Bandwidth test base=1 base*2=3 BW=131168000 Fri 12/23 20:24:06.631 [VideoFrame-0023a5000227@14dc4f6] MiniPlayer got an estimate from the UI on bandwidth of 131168Kbps Fri 12/23 20:24:06.631 [VideoFrame-0023a5000227@14dc4f6] MiniPlayer is using Push mode playback Fri 12/23 20:24:06.631 [VideoFrame-0023a5000227@14dc4f6] MiniPlayer is using the MPEG2 pusher Fri 12/23 20:24:06.637 [VideoFrame-0023a5000227@14dc4f6] Mpeg2Reader is detecting timestamp boundaries in the file... Fri 12/23 20:24:07.791 [AWTThreadWatcher-0023a5000227@1502f0e] EventThread-0023a5000227 Hang Detected - hang time = 751 UILocker=Thread[ActiveRender-0023a5000227,2,main] Fri 12/23 20:24:08.541 [AWTThreadWatcher-0023a5000227@1502f0e] EventThread-0023a5000227 Hang Detected - hang time = 1501 UILocker=Thread[ActiveRender-0023a5000227,2,main] Fri 12/23 20:24:09.292 [AWTThreadWatcher-0023a5000227@1502f0e] EventThread-0023a5000227 Hang Detected - hang time = 2252 UILocker=Thread[ActiveRender-0023a5000227,2,main] Fri 12/23 20:24:10.042 [AWTThreadWatcher-0023a5000227@1502f0e] EventThread-0023a5000227 Hang Detected - hang time = 3002 UILocker=Thread[ActiveRender-0023a5000227,2,main] Fri 12/23 20:24:10.793 [AWTThreadWatcher-0023a5000227@1502f0e] EventThread-0023a5000227 Hang Detected - hang time = 3753 UILocker=Thread[ActiveRender-0023a5000227,2,main] Fri 12/23 20:24:11.543 [AWTThreadWatcher-0023a5000227@1502f0e] EventThread-0023a5000227 Hang Detected - hang time = 4503 UILocker=Thread[ActiveRender-0023a5000227,2,main] Fri 12/23 20:24:12.294 [AWTThreadWatcher-0023a5000227@1502f0e] EventThread-0023a5000227 Hang Detected - hang time = 5254 UILocker=Thread[ActiveRender-0023a5000227,2,main] Fri 12/23 20:24:13.044 [AWTThreadWatcher-0023a5000227@1502f0e] EventThread-0023a5000227 Hang Detected - hang time = 6004 UILocker=Thread[ActiveRender-0023a5000227,2,main]
LaManSoft - InControl For Sage and HomeSeer |
What is your client? Are you using default UI, or gemstone? Do you have fanart enabled?
I ran into an issue with fanart and long pauses on gemstone.
Hi Stuckless, I'm using the standard UI. The only plug-in I've been using is the Comskip Playback plug in.
Also, when I built the Sage V9, I did a clean install (did not upgrade from V7).
HD300 freezes at SageTV logo | brad98 | SageTV HD Theater - Media Player | 8 | 03-31-2012 06:20 AM |
Why does the HD300 Remote Control turn on/off HD300 in other room? | mkanet | Hardware Support | 2 | 09-21-2011 10:55 AM |
Newest Beta Firmware freezes HD300 | teq | SageTV Beta Test Software | 17 | 09-02-2011 04:45 PM |
HD300 freezes after PC sleeps from inactivity | hackzaw | SageTV Media Extender | 9 | 02-19-2011 09:46 PM |
HD300 random freezes | Oddity | SageTV Media Extender | 3 | 01-25-2011 01:59 PM |
