Old 03-23-2018, 01:03 PM
Schedules Direct and Java 10 (not working)
I've been working on a Java 10 container for SageTV and everything appears to work, except that Schedules Direct throws some ssl error. I'm not sure why, but, we'll have to try to resolve this before people start moving to Java 10. (Java 10 was released recently)
Fri 3/23 14:39:37.755 [EPG@3e803b41] Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Fri 3/23 14:39:37.755 [EPG@3e803b41]    at java.base/sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:385)
Fri 3/23 14:39:37.755 [EPG@3e803b41]    at java.base/sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:290)
Fri 3/23 14:39:37.755 [EPG@3e803b41]    at java.base/sun.security.validator.Validator.validate(Validator.java:264)
Fri 3/23 14:39:37.755 [EPG@3e803b41]    at java.base/sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:343)
Fri 3/23 14:39:37.755 [EPG@3e803b41]    at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:226)
Fri 3/23 14:39:37.755 [EPG@3e803b41]    at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:133)
Fri 3/23 14:39:37.755 [EPG@3e803b41]    at java.base/sun.security.ssl.ClientHandshaker.checkServerCerts(ClientHandshaker.java:1947)
Fri 3/23 14:39:37.755 [EPG@3e803b41]    ... 26 more
Fri 3/23 14:39:37.755 [EPG@3e803b41] Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Fri 3/23 14:39:37.755 [EPG@3e803b41]    at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141)
Fri 3/23 14:39:37.755 [EPG@3e803b41]    at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126)
Fri 3/23 14:39:37.755 [EPG@3e803b41]    at java.base/java.security.cert.CertPathBuilder.build(CertPathBuilder.java:297)
Fri 3/23 14:39:37.755 [EPG@3e803b41]    at java.base/sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:380)
Fri 3/23 14:39:37.755 [EPG@3e803b41]    ... 32 more
Fri 3/23 14:39:37.756 [EPG@3e803b41] ERROR Updating EPG Source Local Over the Air Broadcast - N5Y5M4 (sdepg)
Fri 3/23 14:39:37.756 [EPG@3e803b41] ErrorText:expand called on Local Over the Air Broadcast - N5Y5M4 (sdepg) at Fri 3/23 14:39:37.589 expandedUntil=Fri 3/23 14:38:37.410 scannedUntil=Sun 8/17 2:12:55.80:
Old 03-23-2018, 02:04 PM
Taddeusz Taddeusz is offline
Everything I'm seeing is that it has to do with self-signed certificates. Did they change the behavior of ignoring or accepting them?
Old 03-23-2018, 02:13 PM
I don't know much about JAVA, but it looks like you may need to add a trusted certificate store with the root CA and any intermediaries.
Old 03-23-2018, 02:30 PM
Yeah, so it's odd that Java 9 was OK, but Java 10 fails. But, I did find some answers related to importing the certificate, so, in the Java 10 docker container it does now include the certificate for schedules direct. When I put the URL in the browser, it says it's valid, but Java 10 for some reason doesn't like it (it does now, because I added it)
Old 03-23-2018, 02:32 PM
Iím reading that Java 10 has changed the way they source the root CA certs. Might have something to do with that.
Old 04-16-2018, 08:34 AM
atchoo atchoo is offline
Is this still an issue? I recently moved to Unraid-Docker with the java10 install and I had guide data until today where I have No Data everywhere. Maybe it downloaded the guide the first time I installed but isn't able to update it with the java10 install?
(edit) I went back to the sources and configured the EPG again and the guide data downloaded. Not sure what happened, if it will still work in 2 weeks. We'll see.
(edit2) When I restart sage I lose all Guide Data !
(edit3) Might be a problem with a corrupted Wiz.bin... it seems it could be related? If you have hints they are welcome.
(edit4) All good now. I fixed Wiz.bin (it was big and corrupted) and I got my guide data back (had to reload my sources and configurations). So I guess Schedules Direct and Java10 is not an issue anymore because it's all running fine in my install now.
How to Migrate to Schedules Direct? reggie14 SageTV EPG Service 51 10-15-2017 07:34 PM
Schedules Direct - How Far Out Does it Get? mike1961 SageTV EPG Service 7 06-17-2017 11:31 AM
schedules direct garbled epg pschweig SageTV EPG Service 16 04-17-2017 05:28 PM
Using Schedules Direct in UK jamesdisco SageTV United Kingdom 28 02-06-2017 11:54 AM
