Old 05-07-2019, 12:01 PM
pulled in OTA guide data without a epg service
Is there anywhere in sagetv to adjust the setting for this? What is Kaffeine 2.0.5 doing /have to grab the data differently? I am also using Kaffeine which has no issues getting all the epg data. Sagetv seems to be really anemic with the guide generation from ota channels. Is there some code that needs adjusting? I am searching my options away from Schedules Direct.
Old 05-07-2019, 06:14 PM
SHS's Avatar
SHS SHS is offline
what mean by really anemic
Old 05-20-2019, 09:21 PM
By anemic I mean very slow or sluggish response if any. Not sure if it is a sagetv issue or something else going on.
Old 05-21-2019, 10:51 AM
SHS's Avatar
SHS SHS is offline
I see sorry I don't think know if there any way to adjusting that
Old 05-22-2019, 08:29 AM
routerunner's Avatar
Are you talking EPG data from OTA on satellite feeds?
In my experience when I was using it many years ago, data are very accurate in the sense of changes are applied during the day (as long as you tune to one of the channels belonging to the same bouquet or course), but very poor in content, so if you want rich data like actors, director, season numbering, category, then you might find OTA EPG a little bit scarce, but that might have changed now, also I don't think you have more that one day in advance worth of data....
Digital Terrestrial OTA might be different, but I never explored that path.
Cheers
Eddy
Old 05-24-2019, 07:06 AM
I meant terrestial ota signal feed.
Guide Data with No EPG Service EdwardATeller SageTV EPG Service 3 10-16-2018 11:41 AM
Request for pointer to alternate guide data plugin when Sage stops providing EPG data Savage1701 SageTV Customizations 3 04-29-2012 05:50 AM
Step-by-step guide for setting up the XMLTV plug-in for UK guide data dspreadbury SageTV United Kingdom 32 08-17-2010 12:27 PM
Unable to get Guide data for OTA channel that has data at Zap2it wayner SageTV EPG Service 15 07-09-2010 06:23 AM
Hulu pulled from Boxee Brent General Discussion 48 03-26-2009 11:45 AM
