Old 08-23-2020, 09:49 AM
AlphaCrew AlphaCrew is online now
Question Recording (Favorite) to Specific Directory
I know long ago this was not possible; has anything changed in the last 6-8 years that would now allow for a Recording (Favorite) to be recorded to a Specific Directory?
Old 08-23-2020, 12:29 PM
No
Old 08-23-2020, 03:36 PM
The option is certainly available through the web UI
Old 08-23-2020, 04:05 PM
KryptoNyte's Avatar
Please elaborate
Old 08-24-2020, 05:57 AM
This assumes that you have the SageTV Jetty webserver installed.
Then go to Schedule Recordings - Favorites Manager and click on one of your favorites. You should see an option for Original Folder or Alternate Destination Folder which you can then enter.
Old 08-24-2020, 06:19 AM
Does that work even if you are not converting to a different format (i.e. Automatic Conversion=No)?
Old 08-24-2020, 06:34 AM
I just checked, all the same options are available under the standard SageTV gui, the web ui is not necessary. Go to Favorites Manager, click on one of the favorites listed, and there is an Automatic Conversion option towards the bottom of the screen.
But I have a feeling that it only works for files that are automatically converted to a different format, not for the original file.
Old 08-24-2020, 07:02 AM
The other option is to use SJQ to run an external process. I used to have a process that would use handbrake to transcode shows to mp4 and move to a specific folder based on the Show Title.
Old 08-24-2020, 11:04 AM
graywolf's Avatar
graywolf graywolf is offline
I record to a local drive on the SageTV server to a single directory. Then nightly use SJQ to move them to my NAS in Show Title/Season ##/<filename.mpg>
Old 08-24-2020, 11:41 AM
dinki's Avatar
dinki dinki is offline
Can you share how that is done? This is exactly what I'd like to do. I am unfamiliar with SJQ
Intel Core i5-2500, 16GB RAM, OMV Linux 4.17, 3 TB of Data
SageTV 9 Docker, Open DCT Docker
Silicondust HDHomeRun Duo + Quatro
Sage Mini Client on Amazon Fire Sticks and Android TVs
Old 08-24-2020, 11:43 AM
RonBoyd's Avatar
RonBoyd RonBoyd is offline
This is really handy and I wish I had known about. I have four external HDs and multi-episode recordings get spread all over the place. I have had to periodically manually move them to a common location... a real pain.
Old 08-24-2020, 02:25 PM
Thanks for the feedback. Since it appears the embedded solution requires conversion, would if be possible to add a no conversion selection?
Old 08-24-2020, 04:01 PM
graywolf's Avatar
Sure I’ll post the code i use tomorrow
Old 08-24-2020, 04:20 PM
As a test I setup a favorite and selected the conversion type, quality and location. Video completed and nothing happened?
When does this process take place??
Old 08-25-2020, 07:38 AM
graywolf's Avatar
For SJQ.
Attached screenshots of how I have the tasks set in SJQ
Cron entry triggers the TV2Move script which looks for files to move to nas and triggers a movemedia task for each file to be moved
I have had this in place for a long long time. Please review for what might need to be changed for your setup. Been ages since I looked at the code.
I am a Windows setup for the Sage Server and NAS is unRaid.
TV2MOVE:
import com.google.code.sagetvaddons.sjq.network.ServerClient;
import com.google.code.sagetvaddons.metadata.Factory;
import com.google.code.sagetvaddons.groovy.api.MediaFileHelpers ;
// What directory are we moving archives to?
File dest = new File("\\\\tower\\");
// Queued tasks are marked with this metadata value
String SJQ4_QUEUED = "SJQ4_ARCHIVED";
// Are we running on Windows?  File names are not case sensitive on Windows so we need to handle that
boolean isWindows = System.getProperty("os.name").contains("Windows");
ServerClient clnt = new ServerClient();
int i = 0;
for(Object mediaFile : MediaFileAPI.GetMediaFiles("T")) {
    String filePath = MediaFileAPI.GetFileForSegment(mediaFile, 0).getAbsolutePath();
    String ShowName = SJQ4_METADATA.get("SJQ4_SEGMENT_0");
    if(isWindows)
        filePath = filePath.toLowerCase();
    // If the media file is already stored on the NAS, it's already been queued or it's actively recording then just skip it
    if(filePath.startsWith(isWindows ? dest.toString().toLowerCase() : dest.toString()) ||
        MediaFileAPI.IsFileCurrentlyRecording(mediaFile) ||
        MediaFileHelpers.isBeingViewed(mediaFile))
        continue;
       println  (filePath + " to be moved ... ") ;
	   clnt.addTask("MVMEDIALR", Factory.getMap(mediaFile));
       MediaFileAPI.SetMediaFileMetadata(mediaFile, SJQ4_QUEUED, "1");
clnt.close();
return 0;
MoveMedia:
     Move a SageTV Media File
     Last Modified: 16 Feb 2011
            Author: Derek Battams <derek AT battams DOT ca>
    Use this groovy script to move a SageTV media file object from one location
    to another.
    The media file to be moved is defined by the SJQ4_ID environment variable;
    the SJQ4_TYPE variable must also be "MediaFile".  The destination is given
    as the first command line argument to this script.  The destination is a
    directory.
    This script will trigger a rescan of your media after a successful move; the
    rescan is necessary in order for SageTV to recognize the media file in its
    new location.
boolean testMode = false; // Don't actually move any files, just print out what would be done
String flagsFile="\\\\PWM1\\Users\\PWM\\Documents\\SageTV\\Move_Recordings_Output\\HTPC-LR\\Move_Recordings_Output.txt" ;
/******************* DO NOT EDIT BELOW THIS LINE ************************/
// But if you do then send me your bug fix patches! ;)
import org.apache.commons.io.FileUtils;
import static groovy.io.FileType.*;
import java.io.*;
import java.util.*;
import java.text.SimpleDateFormat;
import java.text.DateFormat;
public WriteToFile(String outputFileName, String  content) {
    try {
         File outputFile = new File(outputFileName);
// if file doesnt exists, then create it
         if (!outputFile.exists()) {
              outputFile.createNewFile();
// true = append to file
         FileWriter fw = new FileWriter(outputFile.getAbsoluteFile(),true);
         BufferedWriter bw = new BufferedWriter(fw);
         bw.write(content);
// \n = new line feed
         bw.write("\n");
         bw.close();
        } catch (IOException e) {
            e.printStackTrace();
DateFormat dateFormat = new SimpleDateFormat("yyyy-MM-dd_HHmm") ;
Date runDate = new Date();
//string runDT = dateFormat.format(runDate)
String type = SJQ4_METADATA.get("SJQ4_TYPE");
String id   = SJQ4_METADATA.get("SJQ4_ID");
File dest   = new File("${SJQ4_ARGS[0]}");
String NewShow = "${SJQ4_ARGS[0]}/${ShowName}";
String flagSettings ;
println ("Parm passed = " + SJQ4_ARGS[0] );
println ("New File = ${NewShow}");
boolean RC ;
if(!dest.isDirectory() && !dest.mkdirs()) {
    println("Destination directory is invalid! [" + dest.getAbsolutePath() + "]");
    return 1;
if(!"MediaFile".equals(type) || id == null || !id.matches("\\d+")) {
    println("No media file attributes provided!");
    return 1;
Object mediaFile = MediaFileAPI.GetMediaFileForID(id.toInteger());
if(mediaFile == null) {
    println("No media file for id " + id);
    return 1;
if(MediaFileAPI.GetNumberOfSegments(mediaFile) == 0) {
    println("Zero file segments for media file; nothing to move!");
    return 1;
boolean WatchedFlag = AiringAPI.IsWatched(mediaFile) ;
boolean ArchivedFlag = MediaFileAPI.IsLibraryFile(mediaFile) ;
boolean LikeFlag = AiringAPI.IsDontLike(mediaFile)
int origAiringID = AiringAPI.GetAiringID(mediaFile);
String showExternalID = ShowAPI.GetShowExternalID(mediaFile);
println("Moving " + Arrays.toString(MediaFileAPI.GetSegmentFiles(mediaFile)) + " to destination: " + dest.getAbsolutePath());
// Copy all segments then delete the originals if more than one segment otherwise just do a filesystem move op
if(MediaFileAPI.GetNumberOfSegments(mediaFile) == 1) {
    try {
        if(!testMode)
            FileUtils.moveFileToDirectory(MediaFileAPI.GetFileForSegment(mediaFile, 0), dest, false);
        else
            println("Would move: " + MediaFileAPI.GetFileForSegment(mediaFile, 0));
    } catch(IOException e) {
        println("Failed to move file to destination!");
        return 1;
} else {
    def copied = [];
    // Copy the files to their new home
    for(File segment : MediaFileAPI.GetSegmentFiles(MediaFileAPI.GetMediaFileForID(id.toInteger()))) {
        try {
            if(!testMode) {
                FileUtils.copyFileToDirectory(segment, dest, true);
                copied.add(new File(dest, segment.getName()));
                println("\tCopy of '" + segment.getAbsolutePath() + "' completed...");
            } else {
                println("\tWould move: " + segment.getAbsolutePath());
            println("Error copying segment '" + segment.getAbsolutePath() + "' to destination!");
            copied.each {
                if(!it.delete())
                    println("Failed to delete '" + it.getAbsolutePath() + "'");
            return 1;
println("Moving artifacts...");
mvArtifacts(id.toInteger(), dest, testMode);
if(!testMode) {
    RC=MediaFileAPI.DeleteFile(MediaFileAPI.GetMediaFileForID(id.toInteger()));
    if ( !RC ) {
       println ("DeleteFile failed");
    } else {
       println ("DeleteFile success");
    File NewFile   = new File(NewShow);
    println ("NewFile string = " + NewFile.toString() );
	RC=MediaFileAPI.AddMediaFile(NewFile, null);
    if ( !RC ) {
	   println ("AddMediaFile failed");
   } else {
	   println ("AddMediaFile success");
    Object mfNew = MediaFileAPI.GetMediaFileForFilePath(NewFile);
	if (mfNew == null ) {
	   println ("mfNew is null") ;
	Object origAiring = AiringAPI.GetAiringForID(origAiringID);
	RC=MediaFileAPI.SetMediaFileAiring(mfNew,origAiring ) ;
    if ( !RC ) {
	   println ("SetMediaFileShow failed");
    } else {
	   println ("SetMediaFileShow success");
    if ( WatchedFlag ) {
        AiringAPI.SetWatched(mfNew);
        println("${NewShow} Should be Watched...");
        isWatched = "Watched" ;
    } else {
        AiringAPI.ClearWatched(mfNew);
        println("${NewShow} Should be Unwatched...");
        isWatched = "Unwatched" ;
    if ( LikeFlag ) {
        AiringAPI.SetDontLike(mfNew);
        println("${NewShow} Should be Don't Like...");
        dontLike = "Don't Like" ;
    } else {
        AiringAPI.ClearDontLike(mfNew);
        println("${NewShow} Should be Like...");
        dontLike = "Like" ;
    if ( ArchivedFlag ) {
        MediaFileAPI.MoveFileToLibrary(mfNew);
        println("${NewShow} Should be Archived...");
       isArchived = "Archived" ;
    } else {
        MediaFileAPI.MoveTVFileOutOfLibrary(mfNew);
        println("${NewShow} Should be UnArchived...");
       isArchived = "UnArchived" ;
    AiringAPI.Record(MediaFileAPI.GetMediaFileAiring(mfNew));
    flagSettings= dateFormat.format(runDate) + "|" + NewFile.toString() + "|${origAiringID}|${isArchived}|${isWatched}|${dontLike}" ;
//	println ("Just BEFORE WriteToFile" ) ;
//    println (flagSettings) ;
	WriteToFile(flagsFile, flagSettings) ;
//MediaFileAPI.SetMediaFileMetadata(mediaFile, SJQ4_QUEUED, "1");
println ("Move completed") ;
return 0;
def mvArtifacts(int mfId, File dest, boolean testMode) {
    for(File segment : MediaFileAPI.GetSegmentFiles(MediaFileAPI.GetMediaFileForID(mfId))) {
        String prefix = segment.getName().substring(0, segment.getName().lastIndexOf('.'));
        File baseDir = new File(segment.getParent());
        baseDir.eachFileMatch FILES, {!new File(baseDir, it.toString()).equals(segment) &&  it.toString().startsWith(prefix)}, {
            File artifact = new File(baseDir, it.getName());
            if(!testMode) {
                FileUtils.moveFileToDirectory artifact, dest, false;
            } else
                println("Would move artifact: " + artifact.getAbsolutePath());
Old 08-25-2020, 03:44 PM
Any idea how I can debug this problem? Simply will not work for me. (Win 10, SageTV 64)
Nothing in the sagetv_0.txt file that I can find (assuming this is the log file)
Automatically move specific favorite after each recording finishes TwistedMelon SageTV v9 Customizations 17 01-02-2018 08:04 PM
How to exclude s specific import directory from a view ? hoep Batch Metadata Tools 3 05-18-2011 08:20 AM
New Feature: Define Archive to specific directory jominor SageTV Software 10 02-21-2007 07:10 PM
Is it possible to move a file to a specific directory ldavis SageTV Software 0 09-20-2003 08:45 AM
Prevent recording a favorite on a specific channel BLS SageTV Software 4 08-29-2003 01:05 PM
