Old 07-07-2007, 09:17 AM
MiGster MiGster is offline
No Signal, Signal Strength99%??
I hope this is the right forum.
I have this problem with one channel only. 3-5 WEDUDT5. I can get the ones around it like 3-1 WEDUDT, 3-2 WEDUDT2...ect.
It says I have 99% signal strength then I get a NO SIGNAL message. I have read the FAQ and didn't find anything regarding this problem.
Actually when I scan for channels in the lastest Sage version, 6.1.95, Sage crashes after it scans for awhile, almost always. I had to install version 6.0.18 scan for channels and then upgrade by installing 6.1.95 over it. Any suggestions?
Old 07-07-2007, 02:42 PM
Apap's Avatar
Apap Apap is offline
Same problem here.
I am using a VBox DTA 150 card and cant get that subchannel either. The others work fine though. Also there is no giude data available for the channel 66 digital subchannels. I live about 40 miles from Tampa and am using an amplified antenna that provides 90%+ signal strength. All local broadcast digital channels work fine through my Directv H10 reciever though.
Apap
Cable signal quality issues -- do I need an amp? null_pointer_us Hardware Support 8 02-26-2007 05:19 PM
First time setup - anolog cable signal looks real poor vorius Hardware Support 25 09-19-2006 02:14 PM
Signal mystery pgitta Hardware Support 4 07-22-2006 04:09 PM
"No Signal" with 100% signal strength trini0 SageTV Software 3 03-17-2006 12:01 PM
Stutter/Jitter using A180/Vbox and OTA? Check signal "Strength" not "quality" svemuri Hardware Support 0 12-13-2005 10:51 AM
