Old 10-06-2008, 10:37 AM
electrofex electrofex is offline
Exclamation Basic Cable notch filters
Does anyone know if a Cable company puts a (notch) filter on my line to limit my service to 2-33 channels if this will block the Clear QAM digital channels too?
Old 10-06-2008, 10:42 AM
Brent Brent is offline
It depends. Filters can block a certain range of channels such as 77 - 80, but other filters block out anything above a certain channel. Hopefully the filter you have only blocks a certain number of channels because the QAM typically is in the higher number range. I'm guessing that if the cable company put the filter on, it only blocks a range of channels.
Do you know what kind of filter you have? If you can find the filter it should say what type it is on the filter itself.
Old 10-06-2008, 10:48 AM
As Brent stated, it all depends on what the cable co uses and their policies.
Old 10-06-2008, 02:19 PM
dinki's Avatar
dinki dinki is offline
The cable company can tell you if you can get clear QAM with their basic service. Give them a call and you should get a definitive answer.
Old 10-06-2008, 02:53 PM
matt91's Avatar
matt91 matt91 is offline
I'm sure *someone* at the cable co can tell you, but it'll be a challenge finding them!
Old 10-06-2008, 03:10 PM
heffe2001's Avatar
With the cable co here where I live, if you have cable internet, your QAM channels will also be in the clear.
Old 10-07-2008, 09:34 AM
CollinR CollinR is offline
Yup if you do not have internet through them that may put a low pass filter on your line. Thus far all that I have seen that have cable internet get QAM albit only like 5 worthwhile channels.
Old 10-07-2008, 09:26 PM
Cable Company does not know
My Cable Company does not even egnolage that Clear Quam Channels exists. When I call them or go to their office they say you need a box for digital channels only and have no explanation of why I clame to see digital stuff with out a box. (Charter Cable Glendale CA)
block, channels, clear, filter, qam
Does Basic Analog cable come with Internet service for free? jbarr The SageTV Community 8 06-21-2007 04:47 PM
Interactive Digital Cable Ready oddjob General Discussion 2 03-09-2007 07:58 PM
Cable signal quality issues -- do I need an amp? null_pointer_us Hardware Support 8 02-26-2007 05:19 PM
Over-Air HD and Basic Cable Mix mike400hp SageTV Software 1 02-26-2007 09:36 AM
Basic Cable to Digital Cable.. questions... Stuntman Hardware Support 15 08-01-2006 01:58 PM
