Old 09-21-2009, 09:01 AM
cyberfreak cyberfreak is offline
Comskip problems with QAM recordings (HVR-1800)
I'm using comskip with sagetv and it works fine for SD recordings but if I capture a show in QAM (which outputs as an MPG the same way the SD shows do) I get tons of these errors:
MP3 Audio or other unknown input, cannot decode
Audio PTS jumped 6 frames at frame 37, repairing timeline
Audio PTS jumped 4 frames at frame 44, repairing timeline
Audio PTS jumped 2 frames at frame 52, repairing timeline
Audio PTS jumped 2 frames at frame 55, repairing timeline
Then when comclean runs it complainns the audio is corrupt.
I have the audio set to ac3 in sage, and the properties of the file also say the audio is in ac3.
Has anyone seen this? Is it just that comskip wont work on QAM captures?
1800, comskip, hvr-1800, qam
Hauppauge HVR-1800 And QAM - No Go kmp14 Hardware Support 1 09-06-2009 11:22 PM
QAM issues ... ugh! HVR-1800, 6.4 RC, Vista 64 bit zjennings SageTV Beta Test Software 1 08-15-2008 01:06 PM
Hauppauge HVR-1800 PCI-E 1X and Clear QAM FormatC: Hardware Support 1 07-23-2008 11:06 PM
HVR-1800 QAM Problems w/ WinTV & Sage voetsek Hardware Support 5 06-27-2008 09:58 PM
Setting up QAM on HVR-1800? Coltsicehockey Hardware Support 2 04-10-2008 12:03 PM
