Old 01-11-2010, 10:49 AM
boognish boognish is offline
screen saver image file?
I think this is a pretty easy question- I cant find the image file used for the internal screensaver.
I just want to change the image to something more personalized.
thanks in advance for pointing me to the file
Old 01-13-2010, 03:38 PM
I guess this was a harder question than i thought
im gonna dig deep now.. ill post it if i find it
Old 01-13-2010, 04:55 PM
It is SageTV\SageTV\STVs\SageTV3\SageLogo256.png. You can change that file if you like, or it you want to 'do it right', you can read up on theming, and create your own theme that has a replacement for that file (along with any other changes you'd like to make).
Old 01-13-2010, 09:00 PM
awesome!! thanks for the help!!
i already have a theme that i love.. this is the only part i want to change
thanks again
Old 01-13-2010, 09:45 PM
The SageTV logo is not a themed image; you would have to overwrite the file & then the installer will replace it the next time SageTV is installed. You could write a customization to change it or use the slideshow screen saver option instead -- then it will show your pictures.
Old 01-13-2010, 11:26 PM
huh.. I though that the theming system would check the theme directory first, and if it DIDN"T find it, it checked the base SageTV3 folder. if this isn't the case.. can that be changed??? ;-) seems to make send that way anyways...
Old 01-14-2010, 07:46 AM
Yes, that's the way themes work. But, that has nothing to do with the fact that the logo isn't a themed image. Why support easily swapping out the SageTV company logo?
Old 01-14-2010, 12:44 PM
yeah yeah.. i know, self promotion.. but I'm sure the only reason to change out the SageTV Logo would be to put in a higher quality one, with some color tweaks to match your particular theme.. ;-) C'mon Andy, we all love sage, and I use that logo as my BIOS boot screen.. ;-)
Old 01-15-2010, 08:59 AM
SageMC has other Screensaver options - I know that I use the Photos Slideshow on mine. My wife and I will often just sit and watch the photos roll by.
Old 01-15-2010, 03:05 PM
Default's got the slideshow one as well. It'd be a simple Studio change to switch out the image used by the logo one as well (in studio, do a search for xLogo).
Why should the sage screen saver only work in full screen mode? carlgar SageTV Software 9 07-16-2008 04:11 PM
Blank Screen after Windows Screen Saver TheThumper SageTV Software 3 01-30-2006 06:05 PM
Screen Saver / Lock Screen crashes SageTV crypticgeek SageTV Software 2 10-10-2004 12:09 PM
How can I post a screen image from a MPG file? carlgar The SageTV Community 3 12-29-2003 08:44 PM
Screen Saver Hocky SageTV Software 14 09-08-2003 12:50 PM
