Old 09-10-2010, 10:08 AM
PLUCKYHD PLUCKYHD is offline
Upcoming Netflix/Hulu/Playon support
This support will require the playon importer using it's own import directory. It will not work fully (show banners or filters work). If you don't have it as a separate import path it will not work correctly and will just lump them altogether.
I highly suggest for this and future addins you use a separate import path or the default one playon assigns it.
And I must say this feature is great I now have a separate Neftlix View .
Old 09-10-2010, 04:14 PM
panteragstk's Avatar
Any advice on steps to accomplish this correctly the first time?
Old 09-10-2010, 04:20 PM
Just make sure the configuration of the importer is using a different import library folder then smm or any of your stored videos.( it defaults to this automatically so unless you changed that)
Then just add that path to mymovies collection manager monitoring and you will be good to go.
Old 09-10-2010, 04:45 PM
medwynd medwynd is offline
Glad you mentioned this since I do not use the collection monitoring part of MM. I don't like my machines doing anything without me explicitly telling them to if I can help it :P
Sage on WHS HP MediaSmart Server EX495, 2 x Samsung EcoGreen F3 HD203WI 2TB 5400 RPM drives, HD-HomeRun Dual Tuner, HD-200, HD-300
Old 09-10-2010, 06:12 PM
You don't have to have monitoring on only if you want it to automatically add new items from your que when the que importer updates.
Old 09-10-2010, 08:41 PM
lucasbuck lucasbuck is offline
The importer says 'seemless navigation and playback'. You still can't fast forward anything, since it's still streaming, right?
Old 09-10-2010, 10:55 PM
evilpenguin's Avatar
Yep, that line just refers to that you can navigate to and initiate playback on Netflix/Hulu items like you would any other SageTV content. But once its playing back you're still bound by the limitions of streaming.
Clients: 1xHD200 Connected to 50" TH-50PZ750U Plasma
Server : Shuttle SFF SSH55J2 w/ Win7 Home, SageTV v7, Core i3 540, 2GB RAM, 30GB SSD for OS, 1.5TB+2x1TB WDGP for Recordings, BluRay, 2xHDHR, 1xFirewire
SageTV : PlayOn, SJQ, MediaShrink, Comskip, Jetty, Web Client, BMT
Having a problem? Don't forget to include a log! (Instructions for: PlayOn For SageTV v1.5, MediaShrink)
Old 09-19-2010, 02:00 PM
Is there a way to have the playon movies get metadata separately from the rest of my movies? What I mean is I don't want the playon movies in collection management with the movies I actually have stored locally that way when I delete them from my queue it doesn't cause any problems.
Old 09-19-2010, 02:15 PM
No there is no way of doing this and won't be with any source.
Deleting from your que should not cause issues as long as you are using the mymovies folder monitoring as suggested. The mymovies will remove them automatically once the playon import removes the dummy videos.
Old 09-19-2010, 03:45 PM
wrems's Avatar
wrems wrems is offline
Is it possible, at all, to reset the playback of Hulu and Netflix streams to the the beginning?
Where I've run into problems from time to time is starting a stream and getting part way in and then having to stop and try to come back to it later. What happens is that it never leaves off where I stopped it.
In an ideal world it would be great to have better time tracking from Sage's side that could pass the exact time to jump back into the stream so that it would resume as expected. Otherwise, a way to start the stream over would be good too.
Is this even a possibility? Regardless, of how likely it will/won't be implemented into a plugin...
Old 09-19-2010, 03:49 PM
Peter_h Peter_h is offline
For Netflix, the only way I have been able to reset it is to actually go to a computer and play the movie. Once it buffers all the way, I fast forward to the end and restart the movie. It's clunky but it's about all we can get without native Netflix support.
Old 09-19-2010, 04:13 PM
As Peter said I have no control over this nether does evilpenguin that is a playin thing.
Old 09-19-2010, 06:51 PM
I think what plucky meant to say is that it is a PlayOn thing.
Old 09-19-2010, 07:13 PM
If you navigate to Online->Hulu though the sage menu, then there should be a playback settings item at the bottom and there you can set it to always restart Hulu from the beginning.
And like everyone said, there's no way to do this with Netflix, its a playon issue.
Old 09-21-2010, 02:25 PM
ok, thanks. I just want the collection numbers to be in order. I'm weird that way...
EDIT: OK I did it and I have made a custom view for netflix only per your wiki instructions and all of the movies are showing up in the main wall even though I only have online movies selected and not playon. What am I missing?
EDIT2: Never mind. It fixed itself. Pretty cool. Nice job as usual.
Old 09-24-2010, 09:22 AM
Cascade Cascade is offline
Hi Plucky -- I'm relatively new to Sage --
What is the best way to reach you via email?
Mine is kdoman@cascadedtv.com
We are interested in talking to you about a project involving Sage and your capabilities
thanks
Old 09-24-2010, 09:31 AM
thanks
sagemymovies@gmail.com is the best way.
Old 09-25-2010, 05:43 PM
Qusix Qusix is offline
This is why Sage is the Best!
Linux Headless Server
Tuners: HD Homerun, 2 HD-PVR, PVR-150
Clients:
2 HD100 Extenders
1 HD200 Extender
SageTV Client
Plugin :: PlayOn Hulu/Netflix Queue Importer evilpenguin SageTV v7 Customizations 215 03-24-2011 03:15 PM
Hulu Without Using PlayOn? SDeGonge SageTV Customizations 6 07-29-2010 09:02 PM
HD200 - Playon - Netflix & Hulu import file issues - FIXED! Crunch SageTV HD Theater - Media Player 30 06-23-2010 01:24 PM
Plugin: PlayOn in Online Services (Hulu, Netflix, Amazon VOD, etc.) evilpenguin SageTV Customizations 1513 06-07-2010 02:12 PM
Hulu/playon - in the UK michaeldjcox SageTV United Kingdom 9 12-14-2009 12:45 PM
