Old 09-20-2010, 03:30 PM
Automatic Lookup?
Is there some trick to getting automated lookups working? I have "Automatic Metadata/Fanart Lookups" enabled, but when I record a TV show it doesn't automatically get the fanart/metadata. If I go into the web interface, I can manually update the metadata. Is there something I'm missing?
Also, is there a way to only download certain metadata (specifically season and episode numbers), and nothing else? I don't have any use for the fanart/posters/etc, or the other metadata that is available.
Thanks, and sorry if these are really basic questions but I couldn't find the answers.
Old 09-20-2010, 04:15 PM
If you check the phoenix-metadata.log, are you seeing your items in there. ie, there should be entry stating that it's starting to scan it, and another entry if it updated, skipped, or failed. That's the easiest way to tell if the automatic scanner is working or not. If you are seeing the items in there and they are failed, then we'd need to determine what the show was, etc, and I may need you to send me some logs.
You can't disable certain metadata, but you can tell bmt to NOT download fanart by turning off the central fanart (setting the web ui or plugin)
Old 09-20-2010, 04:33 PM
Great, I managed to turn off the fanart downloading. However I am still getting a poster jpeg downloaded into my recordings folder (next to the recording), how do I turn this off?
I checked the phoenix-metadata.log file and I don't see it even attempting to auto lookup, all of entries listed are from when I manually search for metadata. When is it suppose to look for metadata? When the recording starts or ends?
Sage just finished recording an episode of Friends about 3 minutes ago, but I'm still not seeing anything in the log file about it trying to look up metadata.
Thanks (awesome plugin BTW).
Old 09-20-2010, 04:38 PM
I attached a screenshot of my settings, maybe you can see where I'm going wrong.
Old 09-20-2010, 06:51 PM
Well, the settings look good. As for the .jpg that gets downloaded, that is normal, and can't be disabled (for now). When fanart is disabled, bmt still downloads a .jpg for sagetv, and I never accounted for a case where someone would not want any poster at all
As for the scanning... perhaps you could create a zip of your log files (Tools -> Create Support Request from the web ui, don't include media file titles) and email it to metadatatools at gmail dot com.
Old 09-20-2010, 07:09 PM
I played around with it a bit more and I think it's working now (I had a successful auto lookup for "Chuck"). A couple more questions though:
1) When a file is deleted, will the corresponding poster be deleted as well? It doesn't appear to be.
2) Can the meta data lookup occur at the beginning of a recording instead of when it's finished?
Thanks again.
Old 09-20-2010, 08:20 PM
I don't monitor when files are deleted (I probably should, so i added a bug), so currently bmt does not clean up after itself when files are deleted.
I had to make a choice on when to do the lookup; either on start or completed. I decided on the "completed" status since bmt would not uncessarily fetch fanart/metadata for tv items when you are channel surfing.
Old 09-21-2010, 07:57 AM
How about making a distinction between livetv viewing and favorite recording?
Check out TVExplorer
Old 09-21-2010, 08:11 AM
I'll put some thought into it.... it's now an enhancement req.
lookup.xml for Radio Times data? Alfiegerner SageTV United Kingdom 2 09-09-2007 03:27 PM
IMDB lookup problems Toddupton SageTV Customizations 7 06-28-2007 02:26 AM
EPG Lookup 3DFreek SageTV Customizations 0 08-17-2005 06:53 AM
Automatic DivX Encoding and Automatic Commercial Removal? TurboRX-7 SageTV Customizations 3 07-28-2005 09:00 PM
