Old 09-21-2010, 07:32 PM
SamVimes2 SamVimes2 is offline
Swirly circle of death while watching blu-ray on an extender and pressing guide?
Sorry for the long title. SMM is extremely awesome, and I hope my problem has nothing to do with it, but I figured I'd start here.
I have a repeatable problem on 7.0.16 WHS + SMM + HD200. If I select a ripped blu-ray (i usually use the movie wall view) it plays fine, but if i hit 'menu' or 'guide' on the remote, I get the swirly circle.
The blu-ray will actually continue playing happily until the end, but the unit is otherwise unresponsive and I have to unplug/replug the extender to get it back.
Anyone seen anything like this or have any suggestions? Thanks very much!
Old 09-21-2010, 07:55 PM
PLUCKYHD PLUCKYHD is offline
It is possible it is my addin...could you see I'd it happens if you play the movie through the default interface.
Old 09-21-2010, 08:18 PM
Hi Plucky,
Unfortunately, it works fine in the default interface (but looks way uglier!)
Anything I can do to help pinpoint the problem?
Thanks very much for your help!
Old 09-22-2010, 02:39 AM
Dreameriz Dreameriz is offline
i have noticed this two since the last update of mymovies. where i will get the circle of death.
2-HD200, Win7pro64bit,AMD Athlon II X4 quad620 / 2.60GHz,4gb Memory Speed MHz: 800,320hd for os, scsi 80gb recording+comcerial cutting then transfered to 2tb for tv and movies. 1 HDHR 2x250 nas for other media and a small whs server for backup only
Old 09-22-2010, 04:38 AM
Are you also getting it when stopping a movies playback?
Old 09-23-2010, 04:01 PM
Hi Plucky,
I don't know if this was directed at me, but yes, I also get the swirly circle by simply stopping playback.
Old 09-24-2010, 07:46 AM
For those having this issue what are your watched settings under universal in SMM options?
Old 09-24-2010, 09:04 PM
All four options under universal are yellow (on?) for me, including ShowWatchedDialog and ShowForUnwatched...
Old 09-25-2010, 02:45 AM
yes i am to and mine are all one two
Old 09-26-2010, 07:53 AM
Disabling these two options solved the problem for me.
Old 09-28-2010, 02:43 PM
This issue is fixed in the next build.
Circle of Death Owen Brent SageTV Beta Test Software 9 09-08-2010 05:39 AM
Circle of death tcomeau16 SageTV Software 13 01-13-2010 01:48 PM
Simply play Blu-ray with extender traker1001 SageTV Media Extender 2 09-06-2009 06:41 PM
Switch Blu-Ray Titles on Extender jmctv8 SageTV Beta Test Software 2 05-29-2009 03:51 PM
