Old 09-22-2010, 07:56 PM
Hyrules's Avatar
Hyrules Hyrules is offline
[solved] Api Failing with 1.190 Beta
Hi Plucky,
Today i've started my media center to an SMM not showing in my menu. So i went and look the state of the plugin in the setup menu which was disable. Tried to enable it to find out that the Api failed. Tried to uninstall / reinstall both but didn't fix the issue any way i can help you fixing this ?
**** Nevermind i found out that if your mediaserver has crashed or is down SMM API fails its now fix.
Computer Technician A+ Certified
HTPC : Asrock Ion330HT-BD, Atom 330HT 1.6 Ghz, 4 GB DDR 2, Bluray drive, 320 GB HDD, Win 7 x64
SERVER : Core i7-920 2.4 Ghz , 6 GB DDR3 , 2x1.5 TB HDD + 320 GB HDD (os) , DVD-RW, GB LAN, Win 7 x64
Old 09-23-2010, 06:32 AM
PLUCKYHD PLUCKYHD is offline
Correct if it can't connect to the mymovies database it will fail.
Old 09-23-2010, 04:52 PM
Hyrules's Avatar
Would it be possible to have it display a meaningfull message instead of just failing ? Like unable to connect to the media server.
Old 09-23-2010, 06:13 PM
Out of my control because it throws a exception and sage will just have it fail which is the correct way for them to handle it. Once it fails nothing of smm loads so there is no way for me to display a message.
That being said I can tell pretty quickly from a log.
Old 09-23-2010, 07:13 PM
Hyrules's Avatar
Programmatically it's a way of doing it. It can prevent problem but can cause some like having a plugin failed just because a server cannot be reached. Well... who am i to judge how sage is programmed. I'm thinking myself of programming something for sage but i dont know where to start. I'm pretty advanced in c++, c and .net. I'll have to take some time and look at the code of apis.
Old 09-23-2010, 07:41 PM
Well in this use case it should fail if the SQL server can't be reached then it is a failure that is what the logs are for if it didn't stop it it would keep throwing errors and slow things down considerably.
SMM API install keeps failing craigap Sage My Movies 25 10-06-2010 08:42 AM
Sage API - sagetvmsg.txt - Can API tell if HDPVR Crashed? personalt SageTV Customizations 4 08-25-2010 04:56 PM
File Conversions Failing dadams SageTV Software 37 10-11-2007 11:14 AM
Activation failing Dekard SageTV Linux 10 05-23-2006 06:54 AM
