Old 09-23-2010, 05:59 PM
d2globalinc's Avatar
d2globalinc d2globalinc is offline
Wall View - Right Side covers are cut off.
-- THIS ISSUE WAS SOLVED WITH GOOGLE CODE ISSUE #90 http://code.google.com/p/sagemediama...s/detail?id=90
I'm just checking here to see if anyone else has this issue. The images are cut off on the right side of the wall view.. The last image in each row extends past the edge of the screen.. This happens on my hd300's and windows client...
In basic view - they do not extend past the edge.. The snap031.jpg is basic view.
If this is an issue - I'll post a bug in the wiki then.
- D2G
Old 09-23-2010, 06:11 PM
PLUCKYHD PLUCKYHD is offline
Definately a bug wonder when I broke that...go ahead and bug it please.
Old 09-23-2010, 06:18 PM
Will do! - I never noticed it until today - but today I was actually paying more attention because I was using it to make a custom view..
- D2G
Old 09-25-2010, 07:47 AM
Hyrules's Avatar
Hyrules Hyrules is offline
I also have this "bug" but i though it was made like this.
Computer Technician A+ Certified
HTPC : Asrock Ion330HT-BD, Atom 330HT 1.6 Ghz, 4 GB DDR 2, Bluray drive, 320 GB HDD, Win 7 x64
SERVER : Core i7-920 2.4 Ghz , 6 GB DDR3 , 2x1.5 TB HDD + 320 GB HDD (os) , DVD-RW, GB LAN, Win 7 x64
Old 09-25-2010, 11:46 AM
It is intentional if you are scrolling horizontal but when scrolling vertical it should be the bottom cut off not the side
Old 09-25-2010, 08:47 PM
Hyrules's Avatar
Then its a bug because i'm scrolling vertically.
Old 09-25-2010, 09:02 PM
Yes I said above it was it had already been logged and fixed in the next build.
Old 09-26-2010, 08:15 AM
Hyrules's Avatar
excellent ! Eager to have the next build
Getting fanart in fade out view but not in wall view? medwynd Sage My Movies 2 08-29-2010 04:57 PM
DVD video shifted and right side cut off castylx SageTV Software 3 03-02-2008 10:57 AM
Right side of DVD is cut off ARCJr SageTV Beta Test Software 5 03-02-2008 02:13 AM
Mac & PC editions side-by-side? Richard.Wilkes@ SageTV Mac Edition 1 07-03-2007 11:00 PM
TV Picture Floats side to side in Window or Full Screen J_L_D SageTV Software 3 01-25-2006 09:39 PM
