Old 11-07-2010, 03:33 AM
Empty web lookup
When I do a web lookup on CSI or Bones, it returns an empty screen (all fields empty).
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 11-07-2010, 06:02 AM
David that does seem odd, but it would appear that for some reason it enountered an error. If you can send me the phoenix.log, then maybe there's an error in there somewhere.
Old 11-07-2010, 01:19 PM
Here it is.
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 11-07-2010, 03:17 PM
I did see a failure on TheDefenders-LasVegasvReid-8821139-0.mpg, because it could find the episode, and a failure on, "Sanctuary US" because US was in the title tvdb won't find it. For this file, you'll need to remove US from the title.
As for Bones, I can see that it failed, but it failed because it could not find the title. I tried the same querries on my system, and it did find the correct data.
I don't know why they return no results on your system. It cold be that the item is reading a "cached" result that does not have the entry. You can try deleting the cache directory under your sagetv home directory and then try again.
Old 11-07-2010, 05:23 PM
It was the cache. Deleting it did the trick.
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Imdb Lookup for Person failing pir SageMC Custom Interface 9 10-20-2010 09:26 PM
Automatic Lookup? peternm22 Batch Metadata Tools 8 09-21-2010 08:11 AM
lookup.xml for Radio Times data? Alfiegerner SageTV United Kingdom 2 09-09-2007 03:27 PM
IMDB lookup problems Toddupton SageTV Customizations 7 06-28-2007 02:26 AM
EPG Lookup 3DFreek SageTV Customizations 0 08-17-2005 06:53 AM
