Old 11-22-2010, 07:49 PM
Jesse's Avatar
Jesse Jesse is offline
BMT Auto Lookup
Hi,
I have just upgraded to V7 and installed BMT (first time I have used BMT). Is there anything beyond the "Automatic Fanart/Metadata" setting being checked in the webui that needs to be done to enable automatic lookup of fanart and metadata? I checked the phoenix logs and they showed nothing until I navigated to "browse-->missing metadata-->update metadata." Checking the logs again showed lots of entries. Will I see auto updating from here on out?
TIA
Jesse
Server: Asus P5Q-EM DO, Q6600, 8 Gigs ram, WHS 2011, 1 HDHomerun(x2 OTA), 1 HD-PVR, 1 Colossus, V7.1.9 sage, 3.3 TB vid storage.
HD100 X1
HD200 X2
HD300 X1
Old 11-22-2010, 09:03 PM
Auto updating will only be applied to media files as they are added to the sage library. Any media files that were there prior to bmt will not be scanned automatically. But you can scan them via the UI.
When you add new files to the sage library, you have to tell sagetv to "refresh" it's metadata so that sage knows about the new files, then bmt will automatically fetch the fanart/metadata as well.
Old 11-22-2010, 10:14 PM
Jesse's Avatar
Hi stuckless,
Got it. Thanks very much for the help and all your hard work on this plugin.
Jesse
HD100 X1
HD200 X2
HD300 X1
Empty web lookup davidk21770 Batch Metadata Tools 4 11-07-2010 05:23 PM
Automatic Lookup? peternm22 Batch Metadata Tools 8 09-21-2010 08:11 AM
BMT: Read this if you don't see any BMT topics Opus4 SageTV Customizations 0 04-25-2010 09:17 PM
IMDB lookup problems Toddupton SageTV Customizations 7 06-28-2007 02:26 AM
EPG Lookup 3DFreek SageTV Customizations 0 08-17-2005 06:53 AM
