Old 11-25-2010, 09:05 PM
something fishy something fishy is offline
HD300 deinterlacing
Hi
I've just bought HD-300s to replace HD-100s which periodically locked up playing 720 mkv files (BTW the HD-300s havent locked up once, so I consider that problem solved by new hardware. They're also a much nicer piece of kit).
However the HD-300 deinterlacing seems no better than the HD-100 (which was on occasion lousy). I had hoped that technology had moved on. Is this something that could be addressed in firmware? The HD-300 was updated to current firmware on receipt.
Note that I use the PAL TV system so this is deinterlacing 576i50.
I know about native resolutions but my TV handles resolution and refresh rate changes rather inelegantly so I'd prefer to let the extender deinterlace and scale everything to 720p50.
Eric
v7 and deinterlacing phelme SageTV Beta Test Software 3 09-12-2010 03:57 PM
Deinterlacing question Mahoney General Discussion 9 09-20-2005 07:46 AM
Help with deinterlacing psychoholica SageTV Software 1 06-08-2005 04:11 AM
Deinterlacing weirdness Wheemer Hardware Support 2 04-15-2005 02:45 PM
What kind of deinterlacing are you using for TV out? mlbdude SageTV Software 2 01-12-2004 10:36 AM
