Old 12-19-2010, 01:35 PM
dadavo dadavo is offline
Favorites gone after a rebuild
Hello.
I have recently performed a clean install of Windows Vista on my media center. I previously had SageTV 7 upgraded from 6 running on Windows XP. I installed version 6 and entered my key then upgraded to 7 and entered my key, then launched SageTV to run through the initial setup. I have restored my properties files and wiz.bin from my previous installation and placed them in the SageTV main directory replacing the files already there. When I launch SageTV I have to run through the setup again however this time it already has all of my settings ( tuners, weather zip code, etc). My favorites however are gone. In the past with version 6 replacing the wiz.bin on a new install restored this, but it is not working on 7. I have also restored the entire SageTV folder and still have the same issue. The initial setup has all of my settings but no favorites. How can I restore my favorites?
Old 12-19-2010, 02:03 PM
GKusnick's Avatar
GKusnick GKusnick is offline
Don't restore the properties file from an old installation unless you're restoring the entire installation directory (and all its contents) to the same directory path. The file contains property settings (such as absolute file paths and plugin installation states) that are specific to your old installation and will not be valid for a new, clean installation.
My advice would be to delete the properties file, re-run the V7 installer in Repair mode, and then copy over just your Wiz.bin from the previous installation. Tuner config, import directories, plugins and so on should all be set up again from scratch through the UI, not by copying an old properties file.
Also, it's not necessary to install V6 before installing V7. Just run the V7 installer, and then enter both license keys when prompted.
-- Greg
Old 12-20-2010, 09:43 AM
Thank you. Performing a clean install and moving only the wiz.bin file worked.
Old 12-29-2010, 10:49 AM
DaveS DaveS is offline
I'm about to update my WinXp to Windows 7. I'm currently running version 7 on my WinXp box. I understand that I can copy the wiz.bin file to the new setup but not the properties file. Right now I'm using 3 tuners so I'd like to avoid having to manually re-enter the channel lineups and the remappings of qam stations. Is there a way to move those settings over to the new setup? I've read that you can copy portions of the properties file relating to the tuners but I'm not sure how to identify which lines. (I also use firewire for channel changing on my HD-PVR so I suspect that may add another level of complexity.) Can anyone identify the lines in the properties file that relates to tuners, lineups, remaps, channel changing, etc?)
Old 12-29-2010, 03:36 PM
toricred's Avatar
toricred toricred is offline
If you're using Sage7 there's a plugin to export/import lineups.
Old 12-30-2010, 10:41 AM
Thanks. I'm not sure I understand how to get that. I've looked in the 'downloads' section of the forum at Plugins and Utilities, but I don't see anything that looks like what you're referring to. Could you point it out?
Thanks again!
Old 12-30-2010, 12:59 PM
GKusnick's Avatar
V7 plugins are installed through the built-in plugin manager. Setup > SageTV Plugins > All Available Plugins. That's one of the major new features of V7.
-- Greg
Old 12-31-2010, 09:44 AM
Found it, thanks very much. I've exported the line ups. I'm not clear on whether or not it exports the settings. For instance, I have a digital tuner and I remap the digital stations to the appropriate stations on the EPG. It'd be great if the import/export plugin handles that setting too. Do you happen to know? (It wasn't clear to me in the detailed info that came with the plugin.)
How to rebuild database? Wified Sage My Movies 10 11-19-2010 12:09 PM
Time for a rebuild chughes Hardware Support 4 12-31-2008 08:49 AM
slow operation after rebuild bob_s SageTV Software 3 03-03-2007 10:12 AM
Trouble re registering after rebuild davefred99 SageTV Software 10 02-11-2007 12:31 AM
Lost both tuners?!? Rebuild? cbryan27 Hardware Support 9 03-05-2004 12:04 AM
