Old 12-31-2010, 05:47 AM
Bacon2002 Bacon2002 is offline
HD300 look-a-like
Hi,
Is it just me or does this "Sumvision Cyclone" look a lot like an HD300?
http://www.ebuyer.com/product/245715
Good price and available in the UK but I expect there's no chance it will work with SageTV?
David
Old 12-31-2010, 08:42 AM
matt91's Avatar
matt91 matt91 is offline
Certainly does look very, very similar - at least the form factor does. I didn't compare the listed specs.
I think you're right that there is no way you should assume that it'd offer any "Sage-ability".
Old 12-31-2010, 12:41 PM
Oddity Oddity is offline
Spotted this just the other day, yes the specs look the same and the price is very cheap. I would think the only way to get it to work would be to flash the rom.
Old 01-01-2011, 12:22 AM
MCE-Refugee's Avatar
MCE-Refugee MCE-Refugee is offline
It's very cheap at 55. The WDTV Live which has similar specifications is about 85.
Old 01-01-2011, 04:14 AM
pukka pukka is offline
who's going to try it then?
Old 01-01-2011, 05:59 PM
Nelbert Nelbert is offline
It'll be a safe bet to say no unless someone can change the HD300 libraries and drivers. The Sumvision is a Realtek based unit not a Sigma like the HD300.
The full sized Cyclone enclosures had Mvix and traxdata firmwares flashed into them successfully but when the AC Ryan firmware was tried you got a brick.
The WDTV Live as well as being older is also Sigma based, also worked where as the Sumvision owners went through alot of pain with updates, and for quite a while you couldn't even download the original firmware from Sumvision. It why effort was put into trying alternative firmwares. The Sumvision one sucked.
Sigma players usually cost more than their Realtek equivalent, but Sigma chipsets are proven whereas Realtek came in promising the moon on a stick for less and couldn't deliver and are still going through their teething phase. The original HD Audio capable Realtek chips turned out not to be and it was a silicon problem not an SDK problem, so updated chips were needed. Certain manufactures still kept using the outdated chips claiming HD Audio capabilities though. Hopefully this year Realtek will have sorted out all the Silicon issues and then everything will just be firmware fixes.
Old 02-17-2011, 10:17 AM
SidKnee SidKnee is offline
Hauppauge HD300?
Has anyone tried this new Hauppauge MediaMVP-HD? It's around the same price as an HD300 (if you don't include the import tax), and it says it's a Sigma based unit.
http://www.hauppauge.co.uk/site/prod...diamvp-hd.html
http://www.ebuyer.com/product/251161
Old 02-17-2011, 11:25 AM
Brent Brent is offline
I have one given to me for testing by Hauppauge. Nobody supports it so... save your $ and get a HD300
Old 02-18-2011, 03:00 AM
What support does it need? It's priced almost identically to the WDTV Live & has almost identical facilities. For Sage of course the HD300 is the only choice.
Old 02-18-2011, 08:31 AM
Oh. I thought you were wanting to use it as a HTPC extender - and it's not supported by SageTV, MediaCenter, XBMC, etc etc. It works okay as a media player, but honestly there are others that have much better UI, better online streaming services and more frequent firmware updates. That's my opinion anyway.
Old 07-02-2011, 11:19 AM
SageTV HD300 extender look-a-like
Hi,
I asked this question several month ago in the UK forum, the view was it would definately not work with SageTV but in view of the recent announcements and a need for available HD300s I was wondering if anyone thought this:-
http://www.saverstore.com/product/20...rsion-2--1080p
Could be used as a SageTV extender, no doubt I'm clutching at straws but it does look to be exactly the same (physically) as an HD300.
Anyone think it's worth looking into?
Ta,
David
Here is another one:-
http://www.ebay.co.uk/itm/Cyclone-Su...item3cb993655d
* merged *
Old 07-02-2011, 11:46 AM
logsvp logsvp is offline
As you say, it appears to be an exact duplicate and only 52 quid - a bargain if it could be made to work
Server h/w : MB='ASUS P8P67 Pro', CPU='I5 2500K', Mem='8GB', HD='10.0TB', Tuners='BlackGold BGT3500/3550 (6xDVB-T), TBS 6981 (4xDVB-S2)'
Server s/w : OS='WIN 7 X64', Services=' DigiGuide, SmartPower, STVSMP, MyMovies', Apps='SageTV 7.1.9, LM DVB Smart Recorder, XMLTV Importer, dvblogic'
Client h/w : MB='Gigabyte Z77X-UP5 TH', CPU='i7 3770S', Mem='32GB', HD='10TB'
Client s/w : OS='Win8 X64', Apps='SageTV 7.1.9 Client (V7 STV)'
Extenders : 2 x HD300 (V7 STV)
Old 07-02-2011, 12:47 PM
Spectrum Spectrum is offline
Doubt it. You would need to load the HD300 firmware on it for it to work and from Jeff's previous comments it's not as easy as just flashing the firmware. The conclusion was he was alluding to signed hardware. If anyone on that side of the pond tries it out, let us know how it goes
Old 07-02-2011, 01:01 PM
graywolf's Avatar
graywolf graywolf is offline
Yep, if someone over there got it work, I wouldn't be opposed to buying stuff from across the pond. Wouldn't be the first time.
Old 07-02-2011, 01:35 PM
I would give it a go were it not for me having no idea whatsoever how to go about the whole process.
One assumes the Hauppauge MediaMVP-HD unit does not work with SageTV either?
Old 07-02-2011, 02:32 PM
GKusnick's Avatar
GKusnick GKusnick is offline
That Sumvision Cyclone box is obviously not an exact HD300 clone since it lacks the front-panel IR jack and the rear-panel breakout connector. There's also no DTS decal on the front, for whatever that may mean.
-- Greg
Old 07-02-2011, 03:18 PM
It is a good point that the IR jack and breakout connector are missing so the hardware is not going to be exactly the same.
For information the spec does show that it supports DTS.
Old 07-03-2011, 06:49 AM
starfire starfire is offline
That Sumvision runs a different Realtek chipset while the HD300 runs Sigma.
Old 07-06-2011, 06:06 AM
valnar valnar is offline
I wonder what kind of encryption Sage did with their Sigma boxes and firmware. If we could find the Chinese OEM, maybe we could request some more? Whadaya suppose the minimum run would be?
Server: ASUS P7F-E, Intel Xeon x3440, 4GB RAM, DR-400-6 RM case, 2x Addonics Disk Array 3SA, 7TB disk,
2x Nvidia DualTV, 2x HDHomeRun, HD-PVR 1212, Win7-32bit, Sage 7 latest
Client 2: HD300 on Vizio 40"
Old 07-06-2011, 12:29 PM
GKusnick's Avatar
Those hardware designs and manufacturing contracts belong to Google now (as do these forums). I expect they would not look kindly on attempts to bypass them and deal directly with the OEM.
-- Greg
Want to buy an HD300 ... BUT ... mightyt SageTV HD Theater - Media Player 7 12-05-2010 07:40 PM
HD300 deinterlacing something fishy SageTV Media Extender 0 11-25-2010 09:05 PM
HD300 UI SteinyD SageTV HD Theater - Media Player 29 10-27-2010 08:51 AM
HD300 and the .17 RC Email68 SageTV Beta Test Software 6 09-27-2010 12:38 AM
HD300? jpaddock3000 General Discussion 64 07-04-2010 06:16 PM
