Old 06-10-2013, 08:28 PM
something fishy something fishy is offline
Handling of dates in TV shows
Hi
I'm just starting with this so apologies if this is a simple question.
I have a regular soap opera where the filename is in the format
title YYYYMMDD.pdtv.capper.avi
BMT can't find it (in fact think its a movie) presumably because the date is not being recognised.
What's my best option for handling these automatically? I guess that I could use regex to rename the files to
title YYYY-MM-DD.pdtv.capper.avi
as they are copied into the SageTV import directory. Would that work (do I need to strip the cappers handle and the SD/HD flag from the filename also?) Or is there a way to do it within BMT.
Cheers
Eric
Old 06-11-2013, 06:11 AM
adone36 adone36 is offline
BMT sees the YYYY and assumes it is a movie because that is the movie format it searches for. TV shows are "Title - S01E01" with the season and episode numbers.
Old 06-11-2013, 09:19 AM
YYYYMMDD is not configured in the TV Scrapers. You can try to add a new scraper for this... or it might be easier to rename to the supported format YYYY-MM-DD
EPG Incorrect Original Airing Dates Steve20A SageTV EPG Service 2 01-14-2013 11:01 AM
Recorded TV Dates & Sorting samgreco Gemstone for v7 22 10-25-2012 08:35 AM
File dates/times wrong canned_heat SageTV Software 5 09-22-2010 04:22 PM
New summer show premiere dates malore SageTV Customizations 10 06-10-2004 09:45 AM
Dates reversed in 2-pane view Enormous SageTV Beta Test Software 1 04-19-2004 09:22 PM
