Go Back   SageTV Community > SageTV International User Forums > SageTV Canada
SageTV Canada SageTV and SageTV Recorder Users from Canada - This forum is for you to post about specific issues using SageTV software in Canada.
Old 11-17-2013, 01:59 PM
Usbuirt unresponsive
ok I dont know if it is Sagetv glitch or shaw is playing games with me. after midnight sunday morn my channels stopped changing to record designated channel settings. So when I checked a few shows were recorded to wrong station. My setup was unresponsive ( no signals sent through usbuirt ) & I could only change channels directly with remote. I reset sagetv service & now it seems to be working again. What is happening here? I never had to reset it before & it seems to be like clockwork that it happens sun am.
Galaxysurfer
Old 11-17-2013, 02:24 PM
Paul H Paul H is offline
Did you check the usbuirt USB connection? Try a different port? I had this same problem and found the PC was was 'forgetting" the usbuirt was there. Check under Control panel> System> Hardware> Device mangers> Universal serial bus controllers (XP-PRO) and ensure that the usbuirt is listed. I solved the problem by replacing the motherboard, (there were other problems also). Bon Chance!
Old 12-12-2013, 12:13 AM
i need to reset the usbuirt for it to work. Any other solutions other than changing Mob? I am not really willing to do that since it would mean replacing a few other components as well since cpu etc not compatible with other parts. Feels like a conspiracy to me. all this grief to get & keep sage tv working properly. Is there a setting to alter so system will remember usb-uirt?
Old 12-12-2013, 12:35 AM
found this thread that may fix my issues
http://forums.sagetv.com/forums/showthread.php?t=60854
Old 12-18-2013, 06:50 PM
ok tried that & still no fix for the usb-uirt. My setup was working properly till a month ago when I added a 3rd stb to configuration. I dont get why my usb is now unresponsive unless I keep rebooting it. I think something else is going on. I refuse to replace a MOB as one comment suggested.
Mac Client Becomes Unresponsive After Several Hours jsjb SageTV Mac Edition 2 11-11-2010 07:30 AM
Client 100% CPU and unresponsive sleonard SageTV Beta Test Software 0 08-11-2008 03:10 PM
SageTV Unresponsive During EPG Update themule SageTV Software 10 02-13-2006 05:35 PM
Remote unresponsive kayoti Hardware Support 18 10-09-2005 06:00 PM
Tivo Remote, USBUIRT, and Sage USBUIRT support mikejaner Hardware Support 2 10-28-2004 07:19 AM
