Old 01-09-2015, 08:45 AM
something fishy something fishy is offline
TBS6985 and TBS6285 coexisting
Does anyone have a server with both of these cards working together.
I'm presently using the TBS6985 in Sage, the TBS6285 shows in the device manager (after drivers have loaded after first boot) but neither Sage nor EPGCollector (I'm using Deanm's DDAC) can see it.
Previously I was using the TBS6285 in Sage and though Sage could see the TBS6985, a channel scan yielded no channels and EPGCollector returned error code 3 (no program guide found).
Both work individually but for either the second card added doesn't.
All drivers are current. OS is 32bit Win7.
Old 01-10-2015, 08:34 AM
routerunner's Avatar
Please download diagnostic software HERE and with SageTV server disabled make sure you can actually see and scan both cards.
If the previous step succeeded you know that your PC is not having some sort of incompatibilities as the TBS are well known to be particularly picky on the PCIe bus controller.
Next step is to understand why SageTV doesn't mount both of your tuners altogether, so please look HERE for a suggestion on how to debug native tuner issues.
Hope it helps
Eddy
TBS6985 pukka SageTV United Kingdom 29 10-11-2014 04:07 AM
AirVideo iPad app and SageTV coexisting? tvmaster2 SageTV Software 18 12-07-2012 01:12 PM
How To; Vista Media Center coexisting with SageTV jerryt General Discussion 19 07-26-2008 08:15 PM
Hauppauge PVR 150/250 Not Coexisting Taddeusz Hardware Support 6 06-21-2006 01:47 PM
Hauppauge PVR-350 & PVR-500 coexisting? rwc Hardware Support 7 01-19-2005 01:48 PM
