Old 11-05-2015, 10:30 AM
davidb's Avatar
davidb davidb is offline
Recording schedule file
I need to access the upcoming recordings from an application I am writing and I am almost positive I saw a forum post before on a setting so sage will create a file with the upcoming recordings. I have been searching the forums for 45 minutes and can't find it. Does anyone know how to do this?
Old 11-05-2015, 11:34 AM
I know the webserver is capable of creating an XML file with the upcoming recordings.
servernameOrip:8080/sage/RecordingSchedule?xml=yes
Old 11-05-2015, 11:42 AM
Or... if you are writing an app that is talking to sagetv, you might consider using sagex rest apis.
https://github.com/stuckless/sagetv-...sing-sagex-api
Empty Recording Schedule Fuzzy SageTV Software 17 07-17-2013 10:42 AM
S/E display in Recording Schedule Spectrum Diamond 4 04-08-2011 02:34 PM
Recording Schedule - Beta 6.5.8 jm987 SageTV Beta Test Software 16 02-10-2009 08:25 PM
Copy recording schedule to another PC? wirecreative SageTV Software 7 09-24-2007 02:36 AM
Upcoming recording schedule Stobor SageTV Beta Test Software 1 01-03-2005 02:16 AM
