Old 11-04-2016, 12:35 PM
tvmaster2's Avatar
digitizing from vhs / svhs. HD-PVR?
I'm digitizing some stuff from VHS, and wondered if feeding it thru the HD-PVR is as good as any other method. It looks a little soft compared to the CRT I'm previewing on simultaneously. Is that as good as things get? The sharpness control in Arcsoft just introduces more noise I think
Old 11-04-2016, 12:39 PM
EnterNoEscape's Avatar
The HD-PVR is notorious for softening video in recordings. I don't think there is much that can be done.
Old 11-04-2016, 01:23 PM
HelenWeathers's Avatar
I used to have an s-vhs vcr with Y, Pb, Pr outputs (bought 15 years or so ago) and that gave me best results, followed by s-hvs. From there it's downhill rapidly.
Old 11-04-2016, 09:25 PM
tvmaster2's Avatar
ok, thanks, that's what I was afraid of. I have two SVHS machines, and the Mitsubishi gives a little more detail than the JVC does via the HD-PVR. If anyone knows of an internal card or external box that gives better results and isn't $1000, then let me know.
Old 11-04-2016, 10:36 PM
thomaszoo thomaszoo is offline
I have a Sony digital 8 camcorder that can input composite or s-video and convert that to digital. It did a better job for me than my hd-pvr. YMMV.
i5-6400, MSI B150M Micro ATX MB, 16GB DDR3 1600, 2 - WD Green 2TB SATA Drives, Lite-On SATA 4X Blu-ray Reader, Corsair 400W 80+ Power Supply, Silverstone Sugo SG02-BF MicroATX Case, Windows 10 (64), HDHR Dual X2, Quatro and Prime, 5 x HD300 + 2 x HD100
Old 11-05-2016, 06:05 AM
The Hauppauge WinTV-HVR-2250 and WinTV-HVR-2255 can take both composite and S-Video inputs. I have no idea how the video quality from either of those options would compare to the quality from the HD-PVR. But it might be an option.
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i3-7100T CPU, 16GB Memory, unRAID 6.3.2, SageTV & OpenDCT Dockers
Old 11-05-2016, 08:28 AM
tvmaster2's Avatar
How does it convert to digital - via what kind of output on it's way to the computer?
Old 11-05-2016, 09:45 AM
I had meant to include that, thanks for asking. It is output via firewire and captured as an .avi file.
Old 11-06-2016, 01:32 AM
tvmaster2's Avatar
do you have a capture app of choice? I could use Sony Vegas. Any others?
Old 11-06-2016, 11:44 AM
I have Sony Vegas that I use for editing. But for captures I like to use a freeware program called WinDV. Capturing is pretty much all that it does, so the interface is very simple.
Old 11-07-2016, 01:11 AM
tvmaster2's Avatar
ok, thanks. I'll check it out
Old 11-07-2016, 11:36 PM
A couple things I liked about it was it showed the number of dropped frames (should only happen at the beginning of a sequence) and for digital tapes it did automatic AVI splitting according to the timestamps on DV recordings - every video sequence can be saved into a unique file. Best of luck with your transfers.
Old 11-08-2016, 10:30 AM
tvmaster2's Avatar
thanks - it's amazing how many interesting (to me at least) tv broadcasts, concerts, news items that I have that have never been released any other way, going back to the mid 80's!!!
Digitizing S-VHS to DVD - which tuner card is good for this? tvmaster2 Hardware Support 0 07-01-2010 12:33 PM
Force MVP video output to svhs? Zladotimov SageTV Media Extender 1 12-09-2006 08:51 AM
Only SVHS displayed with WinTV 350 jchiso Hardware Support 3 11-26-2003 12:17 AM
