Old 12-08-2016, 02:19 PM
Cannot Install commons-io-2.4
I cannot Install ... CVF .. Diamond Legacy and others due to that it cannot download commons-io package.
Whoever fixed it thank you.
Old 12-23-2016, 06:04 PM
korben_dallas's Avatar
korben_dallas korben_dallas is offline
having this same problem on a Windows client.. trying to get YouTube working
SageTV server & client: Win 10 Pro x64, Intel DH67CF, Core i5 2405s, 8 GB ram, Intel HD 3000, 40GB SSD system, 4TB storage, 2x HD PVR component + optical audio, USB-UIRT 2 zones + remote hack, Logitech Harmony One, HDMI output to Sony receiver with native Intel bitstreaming
Old 12-24-2016, 12:43 AM
If it's giving you a complaint about not being able to download from sourceforge - that's just a common problem. Try installing it a few times, eventually it will get done. sourceforge's servers seem pretty lazy serving up less frequently accessed files.
Old 12-24-2016, 12:52 PM
Ok downloading it in the browser, but no go through Sage..
Old 12-26-2016, 05:06 AM
crarbo1 crarbo1 is offline
I'm having the same issue as the others. I can download it fine using my browser on my laptop but when going through SageTV on my server it gives me the error. I have tried over and over for the last few days and it doesn't work.
Any help is appreciated,
Chuck
OS: Windows 10 Pro (64 bit)
Motherboard/CPU/RAM: Gigabyte EP43-UD3/Intel Core 2 Quad Q9550 @ 2.83 GHz/8 GB RAM
System Drive : Samsung 850 Pro SSD (256 GB)
Recording Drive's: 2 x WD WD4001FAEX (4 TB)
Tuner's: 2 x Ceton InfiniTV 4's
Clients: 3 x Nvidia Shield TV's; Spares: 2 x HD300's
SageTV v9.1.2.662 with OpenDCT v0.5.28
Java 1.8.0_111-b14 (32bit)
Old 12-30-2016, 03:11 PM
bump, still no DL
Any chance the plugin system could be moved away from Sourceforge to something more reliable?
Old 12-30-2016, 03:17 PM
Originally Posted by korben_dallas View Post
bump, still no DL
I'm not sure if it was coincidence or not, but I upgraded my Java to 1.8 from 1.6 and then every plugin I tried after that worked fine. Maybe that is something you could try if not already on the latest version.
Hope that helps,
Chuck
Old 12-30-2016, 03:20 PM
already on 1.8 but thx for the suggestion
Old 12-30-2016, 03:24 PM
It must have just been a coincidence. Hopefully you can find a fix.
Old 12-30-2016, 06:47 PM
Tiki's Avatar
Tiki Tiki is offline
There was another post in the last day or two from someone having trouble downloading plugin files - the issue was that the download site used an https web address. Sage v9 can handle this, but Sage v7 can not (it only works with http addresses). Could this be a similar issue?
,USBUIRT (multi-zone)
Source:
Comcast Cable
HDHR, HVR-2250
Old 01-02-2017, 01:00 PM
Same problem trying to Install a client for a friend and the download of this library is preventing us from installing plugins. Very frustrating .....
Old 01-03-2017, 01:29 PM
Any word on this as this is killing Plugin Installations ... at least can the person responsible for this plugin respond to what is causing this? ... or am I just wasting my breath pleading for this to be fixed ?
Old 01-03-2017, 02:12 PM
Given that this works in V9... I can say that there is very little chances of this getting "fixed" in v7.
If you are on V7 I would update to latest Java 1.8 and see if that fixes the issue. The issue from what I could tell is a https issue in older java versions.
Old 01-03-2017, 02:34 PM
jusjoken jusjoken is offline
Are you seeing this issue on V9 or only V7 ?
Old 01-03-2017, 02:36 PM
I am on Version nine I will upgrade the Client to java 1.8 if it works then any future releases of Windows V9 should be packaged with Java 8 to avoid these problems.
Edit that worked so it is a Java issue upgrading to Java 1.8 fixed the problem ... thanks for the Suggestion.
I am in the process of loading up a few ASUS Sticks with SageTV I got and will be using them as Clients.
Old 01-03-2017, 03:43 PM
Clean Install of V9 using your Windows Installer.. I had this problem when I was installing my favorite GUI small footprint Plugins that you have authored CVF and Diamond Legacy. Gemstone is great too but these work great on my ASUS Pc sticks.
Old 01-03-2017, 06:28 PM
Both clients on 1.8, same paths in env
Jar and plugininstaller directories look identical, so I copied the commons-io lines from the working client properties file into the problem client properties file. Started up SageTV Client and verified it reported commons-io as installed. Then installed YouTube client plugin, and it worked!
Dunno why one would work and the other not, but got it done the manual way.
Old 02-05-2017, 06:32 AM
michaeldjcox michaeldjcox is offline
I'm seeing this sort of download issue with on a clean install of 7.1.9 sagetv on java 1.8.0_121.
I cannot install any plugin with a sourceforge dependency.
Is there any solution to this?
Web Feed Encoder developer
SageTV Catchup developer
Old 02-05-2017, 06:38 AM
Logs for this:
Sun 2/5 12:36:27.785 [PooledThread@6a460f] Download requested for files server=http://sourceforge.net/projects/sagetv-addons/files/3rd_party_libs/json-20140107.zip/download src=null dest=PluginInstallers\json\20140107.1\httpsourceforgenetprojectssagetvaddonsfiles3rdpartylibsjson20140107zipdownload
Sun 2/5 12:36:28.086 [PooledThread@6a460f] Download remoteSize=178
Sun 2/5 12:36:28.086 [PooledThread@6a460f] Internally processing HTTP redirect...
Sun 2/5 12:36:28.495 [PooledThread@6a460f] ERROR with file download of:javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure
Sun 2/5 12:36:28.495 [PooledThread@6a460f] Resource download failed from http://sourceforge.net/projects/sagetv-addons/files/3rd_party_libs/json-20140107.zip/download
Old 02-05-2017, 07:49 AM
SageTV v9
Install Problem with BMT on SageTV 9.0.4.232 (Fresh install) SWKerr Batch Metadata Tools 2 09-16-2016 03:38 PM
Client Install Hosed Server Install? PeteCress SageTV Software 5 06-29-2015 05:14 PM
Fresh install on new PC - Install at Root of C? hackzaw SageTV Software 5 02-19-2014 04:08 PM
Fresh install or install over existing setup? xj-boonie SageTV Beta Test Software 2 10-15-2010 11:01 PM
Need to re-install windows, how can I backup sage install dwalton22 SageTV Software 3 10-09-2007 10:19 AM
