Old 02-05-2017, 07:48 AM
michaeldjcox michaeldjcox is offline
Windows sagetv client how to change java version it uses
I'm in a pickle.
I reinstalled sagetv.
It installed java 1.8.
Then I found I could not download and install any plugins
So I uninstalled java 1.8.
Server works fine on 1.7 but client says error creating JVM.
I tried uninstalling SageTV and reinstalling.
But sagetv client still thinks its got no JVM.
Web Feed Encoder developer
SageTV Catchup developer
Old 02-05-2017, 07:55 AM
Originally Posted by michaeldjcox View Post
I'm in a pickle.
See Sage FAQ.
https://forums.sagetv.com/forums/sho...802#post346802
Old 02-05-2017, 08:03 AM
Thank for reply.
I cannot see a FAQ that helps though.
Could you spell it out for me please?
Old 02-05-2017, 08:23 AM
Thank for reply.
I cannot see a FAQ that helps though. Go back and read about Installing Java 7 or later it will point you to download and Install the runtimes.
Re-read post I posted. if only updating a Client you do not have to stop the Service.... Just stop the Client
Start reading 4. 5. 6.
Q: How do I update Java on my Windows PC?
A: Exit SageTV and any other application using Java, uninstall the old version of Java, then install the new version.
Before installing a Java update, exit SageTV:
If the SageTV UI is open, close it. If closing it puts the SageTV icon in the system tray, right click on the icon and choose Exit SageTV.
If using service mode, stop and disable the service. This can be done using the SageTVServiceControl.exe utility, found in the SageTV install directory or in Windows' Start -> All Programs -> SageTV, or by running Windows' services.msc service manager.
If the SageTVServiceControl.exe utility is open, close it too once the service has been stopped.
Close any other applications that are using Java. This may include internet browsers.
Uninstall any previous versions of Java. Advanced Java users may not need to do this, but it is recommended for simplicity.
If installing Java version 7 or later, be sure to install the Microsoft Visual C++ 2010 Redistributable runtime files.
Install the new version of Java. There are various sites where Java can be installed, including:
java.sun.com/getjava
java.com
Re-enable SageTV's service mode, if you are using it, and restart SageTV.
Old 02-05-2017, 08:42 AM
Michael make sure you download the 32 bit run times.
Old 02-05-2017, 09:10 AM
Just to be clear.
I had a long running working system with java 1.7 and sagetv 7.1.9.
Had some issues.
Decided to uninstall sagetv, deleted SageTV dir, Reinstall sageTV. Somehow it decided to upgrade to java 1.8 even though I already had java 1.7.
SageTV client and server both ran with 1.8 but I could not install any plugins - nothing would download from sourceforge.
So I decided to uninstall sagetv, uninstall all versions of java.
Reboot.
Install a version of java, reinstall sagetv.
And sagetv client still will not run even though server does.
Normally java is in the PATH and thats how the verison to be used is selected.
Its obviously not happening for the client here.
There must be some registry entry or something!
Old 02-05-2017, 09:20 AM
BTW - Thanks for your replies.
You're talking to a desperate man :-)
Family come home in 1 hour and I've screwed the TV.
I think I already have the microsoft code as I have not removed those since my working system.
I've uninstalled everything, restarted, installed.
Sagetv should not be retaining any memory of of where java was last time it was installed.
Old 02-05-2017, 09:29 AM
Are you sure you have them Installed do not assume re-install them.... better to be safe then sorry. Shutdown your client .... uninstall all Java ... Install the runtimes.... Install Java... Restart Client.
Old 02-05-2017, 11:30 AM
Fixed it.
Prompted by your hints I chose to go to add/remove programs and to repair the MS C++ runtime and then rebooted when prompted.
All is now fine.
Thanks for your help.
Michael
Java version for SageTV v9 oshapir SageTV Github Development 4 01-18-2016 10:48 AM
SageTV 6 Client problems after Java 7 install, Java 6 uninstall alisonnic SageTV Software 5 01-24-2013 02:51 PM
Which Java version for 64 bit Windows? farfromuman SageTV Software 1 02-04-2009 04:35 PM
Which Java version is stable with which SageTV version? reboot_this SageTV Software 2 04-27-2007 06:17 AM
Issues with MVP client, Neilm's Customizable Menus, and java version zubblwump SageTV Customizations 8 09-07-2006 10:12 AM
