Old 08-04-2019, 04:36 PM
mgpaulus mgpaulus is offline
Can I have multiple Sched Direct accounts in Sagetv?
I'm trying to solve this problem:
I have (2) HDHR-CC Cable card tuners, which can do all of my non-premium/non Copy channels. I use this for the bulk of my records, as tuning is never an issue, etc, etc.
I also have an HD-PVR and an HD-3000BMI connected to Xfinity X1 STBs, which I have prioritized for premium channels and copy never channels.
My issue is that both of these tuners are using the Comcast X1 Digital channel list from Sched Direct, but obviously the HDHR-CC adapters are using a subset of all of the channels.
Currently, I have the full listing connected to the 2 STB tuners. And I have mad a copy of the listings for the HDHR-CC.
There are a lot of channels that I don't want and have disabled (such as the SD versions of HD channels, FM stations, Foreign language, etc). However, since my HDHR-CC listing is a copy, and not the original, any time I get a new channel, I have to go into the listing and manually add them.
What I would prefer is to have a 2nd "live" listing for my HDHR-CC so that it reacts the same as the STB tuners, and channels get added automatically.
The only way I can seem to do that on SD is to create and fund a 2nd account. But, if I do this, can I have 2 different SchedDirect accounts configured in Sagetv, or will it update listing 1 to the 2nd account when I do an "update userid/password"?
Old 08-04-2019, 05:38 PM
Tiki's Avatar
Tiki Tiki is offline
I donít think you can have 2 SD accounts in Sage. I think your only other option is to use a different provider for one of your lineups (either enter a different zip code, or select a different provider in the same zip code). But, I donít think that will really solve the problem you are trying to solve, which is to have both lineups update automatically and correctly.
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 08-05-2019, 04:34 PM
KryptoNyte's Avatar
KryptoNyte KryptoNyte is online now
I believe when you make a copy of the lineup that it asks you at some point if you want it to be kept separate and individual from the original. I'm not completely sure if that's what you're trying to do.
You could also select a new lineup for the HDHR-CC and select the same one over again from scratch I suppose, which would also be kept separate from the HDPVR's. I don't know how much of your HDHR-CC stuff is copy-once, but having that update and add channels automatically could be become problematic if it adds a copy-once channel.
Old 08-05-2019, 04:48 PM
Tiki's Avatar
Sage only gives 3 choices - (1) make a brand new lineup(2) re-use an existing lineup, or (3) copy an existing lineup.
If you choose #1, it can't be the same provider as one of your existing lineups - it needs to actually be new and unique.
If you choose #2, it will be exactly the same, so if you disable a channel for one tuner, it will be disabled for all tuners that share that lineup.
If you choose #3, it starts out exactly the same, but it is a separate copy, so you can add or remove channels for just that copy. The problem is that the copied lineups don't get updates. So, if your cable provider adds a new channel, removes a channel, or makes some other change, only the original lineup gets updated by Sage automatically. Any copied lineups don't see the changes, so you have to go back and manually edit the copied lineups if you want them to get those changes too.
So the OP is really asking for a 4th option that would be almost like #3, but would also automatically handle the updates on the copied lineups.
Source:
Old 08-05-2019, 05:33 PM
KryptoNyte's Avatar
I did not know that a copied lineup does not get channel updates automatically. In my local market, new channels are so few and far between that I actually prefer to be notified of the new channel and then control the addition of those channels. It's especially hazardous with Spectrum - if my Ceton cablecard tuner grabbed every new channel, it would mean lots of new copy-once channels that would really muck up the system.
Thanks, Tiki.
Old 08-05-2019, 08:38 PM
JustFred JustFred is offline
Another possibility is to configure one of the Comcast tuners using a channel lineup from a neighboring city (with a different city/zipcode, but mostly same stations & channel #s). All on a single SD account. Comcast publishes their channel lineups on their website, so it's not too hard to research. If you can't find the info on Comcast's website, use a 3rd-party website such as TitanTv.
I've used that trick here in the San Francisco bay area, where Comcast serves almost every city around the bay.
Old 08-06-2019, 05:00 PM
Tiki's Avatar
Right - that's what I meant by entering an alternate provider or zipcode... the only problem is that (a) it might be difficult to find an alternate lineup that is close to the same, and (b) even if it is close, it may not get the same updates at the same time, defeating the goal of having the lineup update automatically when channels are added or removed.
Source:
Direct TV / Dish multiple time zones? tvmaster2 General Discussion 5 06-25-2013 09:18 AM
Multiple Zap accounts bobrap SageTV EPG Service 2 03-13-2006 05:02 PM
Sage Client on machine w/ Multiple XP Accounts nspindel SageTV Software 10 01-24-2006 07:23 PM
SageTV Installation problem: Administrator vs. other user accounts lbouthillier SageTV Software 4 01-18-2006 11:01 AM
What happens to Live TV after sched recording starts? ripple SageTV Software 1 11-04-2005 04:31 PM
