Old 09-22-2008, 07:21 PM
jrhessey jrhessey is offline
online feeds and updates
First off, this is probably a really easy answer, but I REALLY did spend 20 minutes using the search feature on this board and couldn't find the answer. Well, I updated to the latest version over the weekend and imagine my surprise when I go to watch a revision3 feed tonight and it's not there. Well After searching I see that sage has started updating the automatically. After looking at the new version of the file I see that it says to add customizations to the following files.
CustomOnlineVideoLinks.properties
CustomOnlineVideoUIText.properties
My problem... I can't find those files anywhere on my sage pc. Where in the world are they?
**EDIT**
Also, is there a template I can look at or is the setup of the files the same as the old way? Thanks!
Old 09-22-2008, 09:11 PM
There's a sticky in the customizations forum:
How To: Add custom online video feed definitions (default STV; v6.4)
Old 09-23-2008, 05:02 AM
Wow... Thanks! I even did a search for the exact file names listed in that sticky and that post doesn't appear. Wonder why?
Old 09-24-2008, 05:57 AM
garyellis garyellis is offline
FYI....There is a setting that tells SAGE not to do an automatic update. (I wish I could remember where the setting is)..
So, I do it the old way by putting everything in the main files. This way I can customize the names of the "folders" and also delete all the podcasts that I don't want.
The obvious drawback to this is that when a new file comes out, I don't get the newest podcast addresses. But, I download the new files to a separate folder and Sage typically puts the new ones at the end. So, I can pick and choose which ones to add...
Gary Ellis
SageTV V6.4.8 Release Candidate is Here! Narflex SageTV Beta Test Software 0 08-14-2008 05:21 PM
SageTV V6.4.7 Release Candidate is Here! Narflex SageTV Beta Test Software 2 08-12-2008 01:11 PM
SageTV V6.3 is now available for Win/Linux! Narflex Announcements 1 03-07-2008 12:33 PM
SageTV V6.3.10 Release Candidate Narflex SageTV Beta Test Software 0 02-28-2008 06:07 PM
SageTV V6.3.4 Release Candidate Narflex SageTV Beta Test Software 1 12-06-2007 10:27 PM
