Old 03-21-2008, 02:12 PM
Speed up SageTV's startup
There is a new FAQ about how to speed up SageTV's startup process, so it opens quicker. See:
SageTV is taking a long time to start. Is there a way to make its startup process go faster?
Normally, I wouldn't make a new thread just to say there is a new FAQ, but I figured there may be some discussion about people's results after trying this.
Old 03-21-2008, 05:39 PM
Andy,
That works really really well. I don't use IR, so that isn't an issue for me.
Startup of the SageTV service is now within seconds. Nice work!
-Peter
Old 03-21-2008, 05:42 PM
mayamaniac's Avatar
I think this should be a default settings since IR can always wait a few seconds later.
Mayamaniac
Old 03-21-2008, 06:48 PM
Crashless's Avatar
I was just going to start looking at this problem - my wiz.bin has exploded recently from 34mb in november to nearly 70mb currently. (probably because I expanded my tv storage space from about 300gb to 1tb. )
Startup was becoming a chore - I'll take a look at this and see how it goes.
Thanks for posting this!
Give the Meekell STV a try!
Last edited by Crashless; 03-21-2008 at 06:53 PM. Reason: win.biz->wiz.bin same difference
Old 03-21-2008, 08:11 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
Running in Service mode
Set to false = startup 116 secs to usable GUI
Set to true = startup 86 secs to usable GUI
Not quite sure what I'll do with all these accumulating 30 secs. If I restart SageTV enough, I'll have enough extra time to watch something.
John
Old 03-23-2008, 11:12 AM
carlgar carlgar is offline
Set to false = startup about 5-6 minute to usable GUI
Set to true = startup about 90 secs to usable GUI
about 55 minutes till IR recordings started showing up
Old 03-23-2008, 11:36 AM
hemicuda's Avatar
hemicuda hemicuda is offline
I usually time mine based on the listed CPU Time in Task Manager when I can access the web plugin. When set to 'true' the delay dropped from just over 2min down to 30sec . Set to 'false' Sage service would run 98+% for a full 2min during startup. After having typed this and waited for the HD100 to restart the CPU Time is still under a minute and using less than 20% CPU.
for Andy on this tip.
Server: MS Win7 SP1; FX8350 (H2O cooled); 8GB RAM; Hauppauge HVR-2250 (OTA); HVR-1800 (OTA); SageTV 9.1.5.x; 12+TB Sage Storage
Clients: HD300 x2; HD200 x2; Placeshifter
Service: EPB Fiber (1Gb); OTA (we "cut the cord"); Netflix, Hulu, etc.
Old 03-23-2008, 11:45 AM
I'm glad it is working well, but I simply posted the info that SageTV asked me to pass along.
Old 03-24-2008, 05:36 PM
RobJ RobJ is offline
By setting limited_carny_init=true, I can report going from 95 second startup to 44 seconds, on an old slow computer with about 3 to 4 years accumulation, but no IR.
By the way, I noticed disable_carny_init=false, is there any info on what that might do, if set to true? I do not use Intelligent Recordings.
Old 03-24-2008, 05:53 PM
Goodspike's Avatar
Goodspike Goodspike is offline
I think this may only help if you don't use SageService. At least on my fresh install startup takes a lot less time with the service running--it's so short it wouldn't really matter if it was speeded up.
Old 03-24-2008, 10:20 PM
Ryokurin's Avatar
Ryokurin Ryokurin is offline
Send a message via ICQ to Ryokurin Send a message via AIM to Ryokurin Send a message via Yahoo to Ryokurin
Yes. its not that bad on a fresh install. The problem comes like six months down the line, then the old way you would basically sit at the windows 'welcome' screen for a few minutes while the service loads the DB. Anyhow, this option was just what I needed, especially since I didn't use intelligent recordings anyways. I kind of dreaded weekly reboots and that will make it a lot easier to bear.
Old 03-25-2008, 07:55 AM
lamanmi's Avatar
lamanmi lamanmi is offline
Sage was taking quite a while to start, this cut my 100 sec startup to about 60 secs!! Thanks!!
Old 03-25-2008, 05:37 PM
tmiranda's Avatar
tmiranda tmiranda is offline
I avoid this issue by never turning off my Sage server unless absolutely necessary. (I'd estimate that I reboot about once a month.)
Old 03-26-2008, 10:17 AM
Goodspike's Avatar
But I guess what I'm not clear on is this: Does it affect the startup time of SageService at all? On my new computer with the lastest version of Sage, the service seems to take a lot longer to start. Is that due to this or some other factor.
I think that's why I was noticing SageTV taking so long to start--I didn't have SageService running.
Old 03-26-2008, 10:24 AM
This affects the core startup of the server, whether you are using service mode or not. It affects whatever you are starting as the server's recording engine and does not affect a client.
When using service mode, the UI starts as a client & this setting will have no affect on the UI's startup in that case.
Old 03-26-2008, 11:52 AM
Goodspike's Avatar
Sorry I don't understand. So does that mean it does affect the startup time of SageService, if that's what you're using?
Old 03-26-2008, 01:49 PM
Yes, that was what I was trying to say above. It affects whatever you are using that handles the recording schedule & related tasks -- in service mode, that is the service; in non-service mode, that is the UI on the SageTV server.
Old 03-26-2008, 04:03 PM
Goodspike's Avatar
Okay, thanks--that means I should make the change.
I tried to make it earlier but opening the file in Notepad I had an issue saving it that seems to be related to Vista on that computer (not a Sage issue).
Old 04-30-2008, 04:30 PM
md2020 md2020 is offline
Just some feedback:
I made this change last month and while startup time improved, I've slowly seen SageTV performance decreasing. It started with stuttering during HD playback, then slow menu performance, and finally stuttering SD playback. CPU loads were constantly in the 90% range whereas normally I rarely see above 30%.
Anyway, I'm not sure if this setting is what caused the problem but immediately after setting the value back to "false", performance went back to normal and has been that way since. YMMV
Old 10-22-2008, 04:15 PM
Well if you wanted to see an endorsement for the improvement:
limited_carny_init=false - 10 minutes for profiler to initialize
limited_carny_init=true - 36 seconds to have a system
That's almost a 20x reduction in startup time.
What's so bad about SageTV's UI? jbarr General Discussion 155 04-09-2007 04:27 PM
Serious speed fluctuations EChodun SageTV Placeshifter 2 05-23-2006 08:20 PM
ethernet port speed for MVP aoehlke SageTV Media Extender 3 05-18-2006 07:12 AM
MCE Remote/Keyboard Speed Polypro Hardware Support 1 05-08-2006 06:20 AM
Won't open on 2nd monitor on startup. nyle SageTV Beta Test Software 1 04-02-2006 09:20 AM
