Go Back   SageTV Community > SageTV Development and Customizations > SageTV v9 Customizations > Phoenix 3.0
Phoenix 3.0 This forum is for discussing the user-created Phoenix 3.0 custom interface for SageTV.
Old 11-03-2018, 02:37 PM
DaveS DaveS is offline
Plugin install failure
I am trying to install Phoenix Fanart for SageTV and it's failing with the following the attached message. When that failed I also tried P3 with similarly failed. Does anyone know if the files are available?
Dave S
Windows 10, Sagetv 9.1.10, OpendDCT 5.28, 8gb ram, HDHR Prime, 3 HD300
Old 11-11-2018, 10:00 AM
Fixed the issue, I needed to update Java to get all the plugins to work
Dave S
Retrieve Plugin from another install of Sage? UgaData SageTV v9 Customizations 2 09-14-2018 11:47 AM
SlimPlayer plugin install fails on GKusnick plugin scottkoontz SageTV v9 Customizations 11 01-07-2017 07:34 PM
Failure to enable plugin nateziemann Sage My Movies 1 11-10-2010 08:40 PM
plugin, install once, available everywhere? Deacon Crusher SageTV Beta Test Software 4 07-23-2010 12:52 PM
Install auto compress plugin? meno SageTV Customizations 5 09-02-2009 12:26 PM
