Old 12-01-2005, 09:03 AM
wrewing73 wrewing73 is offline
Fullscreen video on TV
I'm not sure if this is the right place to post this but I will try anyhow. I have my TV hooked up to my videocard via s-video. I have my display setings setup as clone and when I play videos either with SageTV or WMP, etc. it shows up on my TV fullscreen the way I want it.
The problem I have is this: When I have Konfabulator (desktop widget program) on it will not show on my TV as fullscreen. It will on show like another monitor hooked up. It also don't work if I enable taskbar transparency with my nVidia nview settings and yesterday I tried installing Windowblinds 5 and it also stole my Fullscreen video from my TV.
Is there anyother kind of settings I can set that it will always show fullscreen on my TV and not look like another monitor hooked up because I use my TV for SageTV viewing and not my PC and I would like to use those other programs without it messing up fullscreen video on my TV. Thanks for anybody that might have a solution.
Windows XP Pro SP2
MSI K8N Neo2 Platinum
AMD64 "Venice" 3200 @ 2.5Ghz
eVGA 6800 GT
AverMedia 1500 MCE
1 GB Corsair Ram
etc...
Old 12-01-2005, 09:27 AM
heffe2001's Avatar
I think the way these programs work, you're not going to be able to do what you want with them loaded. I use Konfabulator & WB5 on my main system at home, and have had some problems with them and some FSE games running, so I typically just disable them when I'm going to be using full-screen stuff.
Old 12-01-2005, 12:26 PM
Do you think TVTool would help?
Windows XP Pro SP2
eVGA 6800 GT
AverMedia 1500 MCE
1 GB Corsair Ram
etc...
