I never put Sage to sleep because it has its own display. However, I do lock the computer when I'm away. Many times, upon unlocking, Sage displays a blank screen. Half the time I can right click and bring back the main menu. Other times the program is completely unresponsive and has to be restarted. It appears to only be the UI that dies, as Sage is often recording something in the background. I've found numerous posts regarding issues similar to this (
for example) but usually there's a variable or two that do not match my circumstances (ie version, hardware, manually put to sleep). Has this issue ever been directly addressed and resolved or is it still open? FSE is off, hardware acceleration is on. I am NOT running Sage as a service.
Software version 4.1.3.67
Java version 1.5.0_06
STV: SageTV3.xml 4.1.3.1
Windows XP Professional SP2
Intel D915PBL
Intel P4 530 3.0ghz
2GB PC2-4200
2x Seagate ST3250823AS 250GB SATA-150
GeForce 6600 PCI-E (HDMI to Sony HDTV + VGA to CRT)
GeForce FX 5200 PCI (DVI to CRT + VGA to CRT)
Hauppauge WinTV PVR-350
