Old 03-16-2006, 01:36 PM
Steve52 Steve52 is offline
Problem playing .wma files?
I finally got around to setting up some music files in STV last night. I moved some .mp3 files I had made from CD's I own and some .wma files I had purchased and downloaded from MSN & Walmart. The .mp3's worked fine, but the .wma files give an error message and will not play. Can someone help me with what is going on here? Is it a DRM thing? If so is there a fix?
Central Sage Server Win 10 64 Bit, Two HD200, Three HD300, & One PC Client 21 TB storage. SageTv 64 Bit
Old 03-31-2006, 09:31 AM
I posted this before and never got any replies so I will try again. I will post a little more information and see if that helps. SageTv will show my downloaded .wma files when I go to the music files section just like it does the .mp3 files I loaded in. It is just that the .wma files return an error when you try to play them and the .mp3 that I made from cd's don't. The .mp3s play fine. It must be a DMR problem with downloaded music? I downloaded the music from another computer in my house and later just copied the files to the HTPC. I own the downloaded music and I would think I should be able to play it on this device or any other that will play the .wma format. Has anyone gotten this to work? How?
Old 03-31-2006, 11:16 AM
I'm pretty sure if it is DRM Sage is not going to play it. You could test this by taking one of your MP3 and using windows media player & encode it into wma. If that plays then you know it is the DRM.
