SageTV Placeshifter Discussion related to the SageTV Placeshifter application produced by SageTV. Questions, issues, problems, suggestions, etc. relating to the SageTV Placeshifter software application should be posted here. |
Playback video is larger than viewable area.
When watching video, whether full screen or not the playback is larger than the video window. I am seeing the upper left expanded to about 2/3 the screen. So I am not seeing the lower right at all. The frame is off. I tried to attach a screen shot but it is blank so I attached a simple diagram to show what I see. Ideas???
http://www.boxpin.com/sagetv
![]() Last edited by Boxpin; 09-15-2006 at 07:29 AM. |
I'm seeing the exact same thing!! Does anyone know how to correct this?
Just guessing at things to look at: Does adjusting the Aspect Ratio Settings in Detailed Setup -> Multimedia do anything? Are you using secondary monitor resolution that is larger than the primary monitor?
You didn't specify what your output is (S-Video, VGA, etc.) I had the exact same problem with my S-Video connection, and I had to play with SageTV's Video/Audio settings in Setup > Detailed Setup > Video/Audio. I'm using an nVIDEA card, and "default" SageTV settings did not work properly.
-Jim Barr SageTVTips.com HTPC: AMD ASUS M2N-E Socket AM2 Motherboard; Athlon 64 3200+ Orleans 2.0GHz; 2GB RAM; eVGA 256MB Geforce 7300LE; 1x40GB IDE HDD (OS), 2xSeagate Barracuda 320GB SATA HDD (Recordings); Antec Overture II Case; Windows XP Pro SP2; SageTV v6.5 STV: SageMC Video sources: Currently, none. I'm using SageTV for Music, Photos, and Video playback. |
I'll try that this evening. I have a NVidia GeForce4 outputing via S-Video. Do you recall which settings you had to tweak in order to correct? |
