Old 04-03-2007, 12:30 PM
jdamore jdamore is offline
Sage Doesn't start until user logs into their account.
Hello folks!
I am having a real problem with my sage server where ill come home from work and it will be at the windows login screen. CRASH!
I would like to setup sage to run when windows starts and not wait until I log in, at least until I figure out the problem. That way, if it crashes, sage will recover and still record even though I am not logged in.
Its possible right? as a service?
IMOA, This should be an option when setting up any sage server.
Jeff
Old 04-03-2007, 12:35 PM
mattdcknsn's Avatar
mattdcknsn mattdcknsn is offline
You need to run it as a service, under the program group there is a program called, sage service (or something like that) and there you can register Sage as a service. The other option is to have your PC auto login with your username, so if it reboots the computer automatically logs in.
Old 04-03-2007, 01:25 PM
GKusnick's Avatar
GKusnick GKusnick is offline
In fact there's a checkbox for it in the installer.
-- Greg
Old 04-04-2007, 09:01 AM
You are referring to the 2nd to last step in the installer (page 13 in manual)? Duh whoops!
I got it now, Thanks!
Now onto trying to figure out whats rebooting my system.. I'm about 90% sure it has nothing to do with sage
Peace
Old 04-04-2007, 09:04 AM
Check your event logs. I have had issues in the past with drivers causing bsod
B
Old 04-04-2007, 09:24 AM
B
YES! Thats what I've been trying to find for the last hour! Can you help me?
Its always the silly little things that stump me.. Scroll up for an example.
Old 04-04-2007, 09:27 AM
right click on "My Computer" and choose manage. Then look on the left for event viewer.
B
Old 04-04-2007, 09:28 AM
sainswor99's Avatar
Are your BSOD's generating memory.dmp files? If so, you can use Windbg from Microsoft to analyze them.
http://www.microsoft.com/whdc/devtoo...g/default.mspx
You need the debugging tools, and a symbol package for your operating system. You then load up the memory.dmp file, type !analyze-v into the console, and it will usually identify the offending process.
HTH,
Stu
Old 04-04-2007, 09:38 AM
brewston brewston is offline
I got annoyed my MS auto-updates rebooting my PC and coming home to find it at the login screen, If you use this link :
http://www.kellys-korner-xp.com/win_xp_passwords.htm
You can set up your TV user to be able to login without a passwd, meaning it will return to the Sage screen on bootup
Hope that helps
Tim
Tecra M5, 2 x HD200, 2 x HD300
2 x PCTV 290e
Win 7, Sage 7.1.9, Phoenix 2 STV
Stephane's XMLTV Importer, Digiguide,
Old 04-04-2007, 09:54 AM
http://www.intelliadmin.com/blog/200...ws-xp-and.html
Just run this utility.
Old 04-04-2007, 09:57 AM
sainswor99's Avatar
Hope that helps
Tim
You may also want to disable the auto-updates altogether; I had issues with it killing my server. I now let them download, but not install; I usually have a patch day once a week where I run them.
Old 04-04-2007, 10:17 AM
Yup - I did that and am now thinking of reverting to manual and doing it myself every few weeks. The PC only runs Sage and sits behind a NAT so I'm not too flapped at the almost daily release of patches. I just had to disable FSE to get the external screensaver working and I don't want constant popups from MS updates
Tim
2 x PCTV 290e
Old 04-04-2007, 10:25 AM
B
WOOOHOOOO! Thats it! THANK YOU
And I'm going to use the auto login as well just in case of a reboot or power failure.
I disabled auto-updates along time ago when I missed my Sunday night lineup.
Plugin: Web User Interface for SageTV 2.2-6.6 (V2.25 18 Sep 2009) nielm SageTV Customizations 2644 10-24-2016 10:18 AM
Poor video quality on some channels JmpnJimBob Hardware Support 6 12-24-2007 12:13 PM
Can't start Sage server... java issues? munch_e_cracker SageTV Linux 7 03-10-2007 05:40 PM
Sage won't start Cleveland1 SageTV Software 12 01-29-2007 09:18 PM
Start sage fullscreen on second monitor ? benny_dt SageTV Software 1 02-06-2006 04:04 PM
