Old 06-06-2007, 05:27 PM
Homebuilder Homebuilder is offline
upgrade problems sage 6.1.9
Hi,
I upgraded from sage 5 to 6.19, everything looked fine. I installed the new versions of nielm's dynamic menus and a few other new versions of stv's, and when I imported the dynamic menus "online services" disappeared as well a a few other menu items. I tried to manually add them back but not go. Had the same trouble on my client box. On my client I uninstalled and reinstalled and it now works fine, but I really do not want to do that with all my favorites, etc in my main sage box.
Anyone know whats wrong with my dynamic menus or sage?
Any way to fix without a new install?
If I new install, what do I need to save and transfer over to save all my info?
Sage 6.19 is up and running now, but want to install the dynamic menus but it messes up when I do...
Thanks in advance...
Old 06-06-2007, 07:38 PM
Make sure you download and Install the latest Dynamic Menus.
Old 06-06-2007, 08:14 PM
Thanks, I did.. but still pulling up old menus from old version of sage and dynamic menus...
Is there is file from the old dynamic menus I need to delete?
Old 06-06-2007, 09:40 PM
You should load this menu file default_menu_V6_1.xml,, then you can customize it again. It should be in the Sage Folder
Old 06-06-2007, 10:34 PM
Tried that, it crashed my system. Wouldnt load. Closed it down, reopened, again, wouldnt load. Had to edit the propertied manually to go back to the other xml...
Sage TV Installation Problems amosisreal SageTV Software 4 06-01-2006 08:00 PM
Placeshifter Problems After Every Upgrade cmaffia SageTV Beta Test Software 0 04-03-2006 06:40 AM
Sage crashes rfutscher SageTV Software 0 01-23-2006 04:31 PM
Sage upgrade and extender experience flavius SageTV Media Extender 0 01-06-2006 09:26 PM
Suggestions for improvement tooslow SageTV Software 15 12-25-2005 03:17 PM
