Gb NICs inconsistent speed
Searched the forum but could not find...
I have a problem with the 2 Gb NIC adapters on my server. When the server is restarted, it is hit or miss connection of 100 Mb or Gb speed. Restarting can give different results although the actual hardware has not changed. Environment: NICs on the mobo Both plug into Gb switch with CAT5e cables I looked into BIOS settings with no luck Unplug and plug in does not work Disable and repair functions do not work Also, I plan to have my HDHR connected directly to my server but I have not done that yet. Just affraid to change what works. Any other way you can think of to utilize both the NICs or is that happening already? I have only seen activity on 1. Will the other pick up if the first is saturated.
Server: Intel Core 2 Quad Q9550 (2.83GHz, 1333FSB), Asus P5B Deluxe MB w/Gb LAN, 4GB AData RAM, WHS, PVR-500 (NTSCx2), HDHomeRun x2 (4 QAM), HDPVR x2, 6.7 TB data pool, Comskip/SJQv3, HD200x3, SD-MVPx2 |
There is a good reason why only 1 Nic is getting used and the other is being ignored. Unless, you have Link Aggregation or NIC Teaming capabilities with your router and/or your computer you will only be able to utilize 1 NIC per network. The switch or router is actually blocking the one NIC to prevent Packet Storms. A Packet Storm is lots of data flowing between the two NICs and does not know where to go, and this will severely degrade overall network performance.
Link Aggregation and/or NIC Teaming allows multiple NICs to work together however. This is a feature typically found is higher end switches. If you got you router/switch at Best Buy or something similiar it more than likely does not have this feature. These switches typically run in the $300+ range for an 8 port switch. NIC teaming is a feature found on server class NICs that have dual or quad NICs integrated on a single card (PCI, PCI-X, PCI-e) and integrated on some Server class motherboards. If your motherboard is geared for home users (most are) then you probably have 2 NICs that are made from separate companies. Again I am speculating on what you are using, and please feel free to correct me or supply me with specs. If anyone knows of a way to have two different NICs work together please let us know. Hope this helps, Protoman
Server: Synology DS1019+, 2x WD Red 10 TB, 2x HVR-950Q OTA Old Server: ASRock Z77 Pro5-M, Intel i3-3225, 16GB RAM, 2x HVR-1800 OTA, 2x HVR-950Q OTA, 2x HD-PVR w/SPDIF (Not in use), 2x 1TB WD Black, 2TB WD Black, and Windows 7 Professional 64-bit. - 1x HD 300 - 2x HD 200 |
I think the problem is a crappy NIC, NIC driver and/or switch/router. My desktop PC is running on a P5B (none deluxe) and has the same problem. After a reboot it might only connect at 100MBit. After disabling and reenabling the NIC it connects with 1GBit. I think this is caused by the Realtek Chip that Asus uses. Martin
Main System: Athlon X2 +3800, Asus A8N-E, 4GB RAM, 1x 200GB SATA, 3x 400GB SATA, 1x 500GB SATA, Geforce 7600GT, 1x Hauppauge PVR500, 1x Hauppauge PVR150, SageTV 6.2.4, XMLTV+Clickfinder to XMLTV, Windows XP Pro Bedroom: Hauppauge MVP |
Can't you turn off autonegotiation and force it to connect at 1000Mbps on the Advanced tab of the NIC device properties?
-- Greg |
I looked in the device properties and could not find it. I will look again when I am home. Thanks.
have the gigabit NICs ever worked?
are there any other working gigabit devices on the network? answering these questions may help determine whether it is a problem with the router/switch or with the NICs themselves.
MacBook Core2Duo 2 ghz nVidia 9400M GPU 46" Sammy HLP4663 720p DLP 2x HDHR, all OTA QNAP TS-809: 12.5 TB for Recordings/Imports/TimeMachine/Music HD200 via 802.11n in Living Room 802.11n client in bedroom |
Green, Gbps Amber, 100 Mbps The problem is Gb connection is not consistent. I have 1 other Gb item on the network. See attached. You asked. It works fine as far as I have seen but to be honest, I have not looked at it on a regular basis.
you will be able to set (probably on both side, but only one should be necessary), whether that port or NIC uses autonegotiation. You can do that on the switch, or in the NIC driver settings/properties. This used to be a really common problem with autonegotiation not always working between different equipment, doesn't surprise me to hear it. As well, it may be that your wiring is a little deficient, and so you are just on the border of being able to support/not support GB during autonegotiation.
Cory PS. and I echo everything that was said at the top about two ports and two nics. you should really be using only one unless you know both are operating. |
I tried setting it to fixed speeds but then I lost all network communication. WinXP said 1Gbit link but I was unable to ping anything.
For a reliable GB connection you need all 4 pairs of the network cable to be functional all the time. I have seen cases where a cable rated for GB, works AOK for 100MB, but not at all with GB. Testing showed a bad pair. Perhaps you have cable that is flaking out sometimes.
Try a new cable and see if it helps. Watch out for kinks and such in your cables. http://en.wikipedia.org/wiki/Gigabit_Ethernet "1000BASE-T requires all four pairs to be present and is far less tolerant of poorly installed wiring than 100BASE-TX." |
reading that article a little further down reveals that auto negotiation is a required part of 1000BaseT: "Autonegotiation is a requirement for using 1000BASE-T[2] according to the standard" it includes a link to the IEEE's specification PDF
Maybe so, but there are various flavors of autonegotiation. My NIC driver includes a setting for "Autonegotiate for 1000FD" as distinct from "Full autonegotiation".
But as others have said, the simplest remedy might be to swap out the cable for a new one and see if that makes a difference.
-- Greg |
if forcing gig speed doesnt work, then you may need to do it on both sides. |
First, I tried to disable my other lan adapter and then my HDHR stopped working. So it must be using the adapter for something. I did not have time to fool with it anymore as primetime was about to commence.
I checked and there is no option for 1000bt. Only 100bt full/half-duplex, 10bt full/half duplex, and auto. This makes sense given the article mentioned above.
Both built into the motherboard. I am going to try disable again first and reboot. I think if it sees there is only 1 available, it will solve the problem. However, I may just wait until I can have the HDHR through the 2nd NIC directly. That was my original intention with the 2 in the first place.
Make sure the cable you're using is a Cat 5E or a Cat 6. Cat 5 won't cut it.
They are CAT5e. You can see my network in the PDF I posted.
Still having this problem. Now I do not have both NICs connected to the switch. 1 is directly connected to the HDHR. The other is connected to the switch. The 1 that is connect to the GigB switch does not always connect at GB speed. Anyone? Thanks.
Have a look in the switch config to see if you can force (or suggest as noted above) gigabit. Check the driver configuration on your server as well. Then try a known good cable? I'm afraid I don't recall all the steps you've already taken from the last time I read through everything.
Im afraid I dont know what a HDHR is, but I can tell you that generally speaking there are very few situations in which random hardware would work in such a configuration without specialized knowledge and configuration. However, I'm speaking from ignorance about that particular hardware, so perhaps it is designed to support a configuration like you mention in which case, please ignore what I've said. The point being .. that this would seem to introduce a wild card into the equation that would be easier left out completely. |
HD Recordings are inconsistent. Some great. Some Awful. How come? | dale_ander | Hardware Support | 1 | 11-08-2006 10:18 PM |
Looking for a no-hassle SageTV "serial" cable (PC USB--> DirecTV Low Speed data port) | mkanet | Hardware Support | 11 | 06-16-2006 09:29 AM |
Serious speed fluctuations | EChodun | SageTV Placeshifter | 2 | 05-23-2006 08:20 PM |
ethernet port speed for MVP | aoehlke | SageTV Media Extender | 3 | 05-18-2006 07:12 AM |
MCE Remote/Keyboard Speed | Polypro | Hardware Support | 1 | 05-08-2006 06:20 AM |
