Old 06-17-2008, 01:06 AM
zzmystique's Avatar
zzmystique zzmystique is offline
Guide to setup sagetv server master for network encoders.
I need some advice on how to setup up a windows xp pro pc (that has no tuners) as a sagetv server master that would control 3 network encoders pc's each with 7 tuners. I was considering using a wmware guest.
I want my clients to connect to the master only using a web interface, to download recordings from the pc and set up recordings.
On the network encoder I have set the property 'enable_encoding_server=true'
and on the master set the property
'network_encoder_discovery=true'
The master PC doesn't see the network encoders at the moment, also how do I get the EPG from network encoder to show up on the master? (3 of the Source network encoders are DVB-S)
Anne
ZZMystique
My setup: Server: SageTV v7, Intel i5, 8GB, 180GB SSD, 4TB HDD, Win7HP & (DVB Viewer Pro with DVB Viewer for SageTV using 2xTBS6281 DVB-T2).
Old 06-17-2008, 09:06 AM
Are the firewall ports listed in Appendix G of the PDF manual open?
And, I think the EPG would have to work through the server, not on the network encoder.
Old 06-19-2008, 05:22 AM
zzmystique's Avatar
Question
Thanks for replying Andy, the firewall ports have been configured. I think my issue with the master not seeing the network encoders is because they are on different subnets.
What lines do I add to the master servers sage.properties file so the network encoders will be discovered?
What configuration needs to be done on the network encoder?
Anne
ZZMystique
Old 06-19-2008, 05:33 AM
Interesting.. Since SageTV does a broadcast discovery, I think you may need to submit a feature request. In the mean time if you can configure your router for packet forwarding I would. You could start with just the outbound packets from the master server. You could also try setting up the encoding servers on the local subnet and then modifying this porperty:
mmc/encoders/tuner number/encoding_host=ip_address\:6969
Also, on the encoding server you don't need to configure anything EPG related. I set mine to use none, but you do need to configure the external tuning setup if required. It is all handled by the master otherwise.
Old 06-19-2008, 06:25 AM
zzmystique's Avatar
Doh! Going to have to re-think the setup as there are too many routers between the master server and the network encoders (the network encoders are located on a different physical site (10km apart)).
Is there another way to get the guide epg data and recording info from 3 sage servers and merge together? (I'm no programmer!)
ZZMystique
Old 06-19-2008, 11:39 AM
I was thinking about this some more..
ssh supports local and remote port forwarding. You could try something with that and open tunnels. You could also place the servers in a vlan too. If it would help, I could paste in my network encoder, but you might be better off putting SageTV on a laptop and taking it to each remote server to build your properties.
B
Beginning setup of a Sage server gensuz Hardware Support 11 03-04-2008 07:25 AM
Setup conflicts between Different Encoders - Programming Question abasu2003 SageTV Studio 3 03-03-2007 08:13 AM
STV: Cayars17 Ultimate STV (Release 17 - Jan 18) Cayars SageTV Customizations 3664 12-13-2005 05:35 PM
